@Sharkie: Hi.
hmm....... a couple of unknowns that make answering your question a tad problematic!
- Which diagnostic device are you using? Maybe VCDS - because you refer to "09 - Cent Elect."?
- Does the hex09 module on this car actually have an active long-code string (not sure what is meant by "Long Coding, no checkbox exists for foglight")?
Anyhow - disabling the front fog-lights involves 2 x separate processes - like this:
First, you need to tell the hex09 module to no longer recognize the center-turret first-click position on the rotary-light-switch which enables the front fogs on a mk7 and I assume does the same on your Polo. To do this on a hex09 module that does NOT have an active long-code string, do this:
- ENG141656-MAS10541-Auflenlicht_uebergreifend-Light rotary switch with fog light > No (Yes)
If this car DOES have a hex09 module with an active long-code string, the equivalent facility will be on one of the software switches in the Byte/Bit library (the descriptor on the long-code helper screen should have a similar name if you are using VCDS) - see below:
Second: the change above stops the rotary-light-switch from activating the fog-light - however, these lamps are also activated by the Static AFS function which operates the cornering-light facility. So, you will also need to shut-down the 2 x Leuchte-sets that control the fog-lights (there is a separate Leuchte-set for each lamp).
The changes to disable the front fog-light Leuchte-sets are:
Left-Side
Leuchte12NL LB40-Type_Of_Load_12 > nicht aktiv/not active (allgemeine Scheinwerfer)
Leuchte12NL LB40-Lampendefektbit_Position_12 > 00 (3 )
Leuchte12NL LB40-Fehlerort_mittleres_Byte_DTC-DFCC_12 > 00 (22)
Leuchte12NL LB40-Light_Function_A_12 > nicht aktiv/not active (Nebellicht links)
Leuchte12NL LB40-Light_Function_B_12 > nicht aktiv/not active (Abbiegelicht links)
Leuchte12NL LB40-Dimming_AB_12 > 0 (100)
Right-Side
Leuchte13NL RB3-Type_Of_Load_13 > nicht aktiv/not active (allgemeine Scheinwerfer)
Leuchte13NL RB3-Lampendefektbit_Position_13 > 00 (42)
Leuchte13NL RB3-Fehlerort_mittleres_Byte_DTC-DFCC_13 > 00 (23)
Leuchte13NL RB3-Light_Function_A_13 > nicht aktiv/not active (Nebellicht rechts)
Leuchte13NL RB3-Light_Function_B_13 > nicht aktiv/not active (Abbiegelicht rechts)
Leuchte13NL RB3-Dimming_AB_13 > 0 (100)
Notes:
- I've not shown the "Parent/Child Tag-numbers" on the adaptation channels above if you are using VCDS
- The values in brackets should be the default values as factory-set on your car - if these values are not as shown on your car, further discussion is needed!
Reason: xhanged "0" to "00" in Lampendefektbit & Fehlerort_mittleres channels
