Hi all
I would really appreciate if some of you VCDS guru's could help me with which byte/bit I need to toggle in VCDS to activate power from the B12 pin (Terminal 58d) on the on board supply control unit J519 in my 2008 Tiguan Tdi. This circuit ( gray wire) supplies power to the 2 background LED's in the dome light and also where fitted, LED's mounted is some of the cigarette lighter sockets located in the centre console and the ESP switch.
I have looked at the long coding in both module 9 & 46 with no luck. I have noted in module 9 there is an 03 output test for terminal 58d but I am not sure if it refers to that specific b12 pin or another circuit b11? which is also part of the interior lighting (terminal 58d?)
If anyone can help I can send them a scan of my module codes. I understand these background lights are fitted std in golf 5 gti's
Thanks in advance
