Results 1 to 5 of 5
Thread: Coding of 3AA 614 109 AF ABS module for TPMS
    May 2014
    The Hague
    I own a Passat Variant B7 from December 2012 and I would like to activate Tire Pressure Monitoring System via ABS (4C), but I cannot find any information about how to code my ABS module type: 3AA 614 109 AF to enable this.
    The current value is 0000378. According to VCDS I should add +1024 to the value for TPMS (PR-7K6), however value 0001402 is not accepted. (“Out of Range”)
    I was able to read the values of another B7 Passat which has TPMS. The ABS module of this Passat is type 3AA 614 109 AC and the coding is 0001414. But my Passat has autoparking which also requires a setting in the ABS module.
    Does anyone know which coding I should use to enable TPMS on my Passat?
    May 2013
    Orange NSW
    You maybe mixing hex and decimal codes together. Can you post a snap of the vcds screen.
    08 MY09 R32, DBP, DSG, GIAC, R8V10 reps, KW V3, RNS510/VIM/BT/MDI, region free DVD, switched Haldex, s2t paddles,HPA dogbone rubber,Mk7 climatronics, FIS+, Adams/RDA discs & Hawk pads, Garage button, GruppeM. Front fogs, Milltek. CF Chin spoiler.Strut support. LEDs Alloy front suspension bits.....
    http://photobucket.com/gregsr32
    Erskineville, NSW
    Can you post a shot of the yellow coloured screen that comes up with all the numbers on it please?
    May 2014
    The Hague
    Here is the screen:
    Coding of 3AA 614 109 AF ABS module for TPMS-abs-jpg
    Attached Thumbnails Attached Thumbnails Coding of 3AA 614 109 AF ABS module for TPMS-abs2-jpg
    Erskineville, NSW
    Sorry, can't help. My yellow screen had about 10 numbers to mix & match.
    Have you flicked an email to RossTech?
