Back completely out of the module, to the home screen, and cycle the ignition.
If that doesn't work, then perhaps that function isn't supported by the control module.
Hi guys
I'm new to this. Ive just changed some coding using the long code helper and ticked a few functions, push the "Do it " button and with a messagd saying it done but nothing happens. Nothing i actioned works.
Any advise?
Thanks
'07 Transporter 1.9 TDI
'01 Beetle 2.0
There are loads of functions it has listed that dont work on the car its plugged into...VDUB..
VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150BRISBANE / GOLD COAST
Thanks for the advise.
I'll try cycling the ignitions and see if it works. I can understand i one or two don't work but every one I've tried has not worked.
Well I've tried cycling the key have got a few functions to work. I think my Multivan comfortline has a different module to the highline. I'll research more into it.
Thanks for the help
Yes, the Highline will have a different module in it.
'01 Beetle 2.0
