Results 1 to 3 of 3
Thread: Checking correct timing belt installation in VCDS on MK4 Golf
    Apr 2012
    Peninsula, VIC
    Hi Guys,
    Finally received my dongle and im able to connect and read fault codes etc. But i cannot find where to check correct timing values in the measuring blocks. What am i missing??
    Ben
    What engine? There's no adjustments to make that I am aware of, certainly on a GTI.
    Apr 2012
    Peninsula, VIC
    sorry newbie mistake... 1.8 AGN N/A. I did all the timing belt/waterpump tensioners etc myself (aligned everything on timing marks (flywheel,cam gear)) and everything is fine just wanted to know if theres a way i can check if im a tooth out or anything via VCDS. As I said nothing suggests it is as its running fine but would like to double check.
    Cheers,
    Ben
