Results 1 to 10 of 11
Thread: Check bulb light
Gimp101 Check bulb light 03-09-2016, 01:46 PM
kamold You clear it by replacing the... 03-09-2016, 01:59 PM
Gimp101 Installed LED's for the... 03-09-2016, 02:07 PM
kamold If they are not canbus... 03-09-2016, 02:16 PM
JustCruisn Disabling cold diag will only... 03-09-2016, 02:46 PM
Gimp101 I purched my LED's from BMR... 03-09-2016, 02:53 PM
kamold Not all 'error free' bulbs... 03-09-2016, 03:41 PM
Lucas_R Check bulb light 03-09-2016, 03:45 PM
Gimp101 These look good. Im assuming... 03-09-2016, 05:06 PM
Lucas_R No errors. Had then about... 03-09-2016, 09:49 PM
The_Hawk It's possible to code them... 03-09-2016, 09:17 PM
    Jun 2014
    Hills Area, NSW
    Check bulb light
    Hey guys, just need some assistance with clearing the check bulb dash light and also would it be possible to deactivate that feature aswell? Located in the Baulkham Hills area. Thanks.
    You clear it by replacing the faulty bulb.
    Have you installed some leds?
    If so where?
    What sort of car?
    Jun 2014
    Hills Area, NSW
    Installed LED's for the number plate lights. Its a mk6 golf gti.
    If they are not canbus friendly (IE have inbuilt resistors to simulate a filament globe) coding the bcm for cold lamp diagnosis may not stop the fault.
    But we can try. I'm in the Hills also.
    Jul 2007
    Brissy
    Disabling cold diag will only delay the warning light.
    Cold diagnosis is done before the light it turned on, at start up vs checking when the tail light is turned on.
    I have tried a few ebay brands of Can Bus LEDs and they all throw codes.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Jun 2014
    Hills Area, NSW
    Quote Originally Posted by JustCruisn View Post
    I purched my LED's from BMR Autowerks in Auburn. It said on the website error free, but i guess not. Honestly im happy with the quality of the LED's just a bit annoying having that bulb check light on.
    Not all 'error free' bulbs are created equal.
    Equally not all BCMs are as sensitive to having LEDs rather than filament globes.
    The only guaranteed fix is to use either OEM LEDs, or inline resistors.
    With that said I have through trial and error managed to get reliable, error free LEDs installed almost everywhere without the need for additional resistors.
    YMMV
    Check bulb light
    You need the LED's from Bold Sport - they are error free. Otherwise you need these for the Mk6 GTI which i have.
    JOM numberplate lights.
    Jun 2014
    Hills Area, NSW
    These look good. Im assuming it didn't give you an error light?
    Quote Originally Posted by Gimp101 View Post
    No errors. Had then about 18months now.
