Sorry, I can't help. But if it makes you feel better mine is exactly the same.
Hey,
I have just got my cable from Ross-Tech and ran a full auto-scan. I have done nothing to the car since owning it (at 63,000km), but there seems to be a CanBus coding error. Full scan is below, can anyone help? (I forgot to save, but the radio doesnt error anymore, it has standard 310)
Friday,19,August,2011,18:16:51:06802
VCDS Version: Release 10.6.4
Data version: 20110418
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 47 52 55 56
VIN: WVWZZZ1KZ7W093659 Mileage: 64510km/40084miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Not registered 0001
Address 01: Engine Labels: 022-906-032-BDB.lbl
Part No SW: 022 906 032 CD HW:
Component: MOTRONIC ME7.1.1G 7802
Revision: --H02--- Serial number: VWZ7Z0F8163369
Coding: 0000172
Shop #: WSC 01287 785 00200
VCID: 4F83A745A74D
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
Component: ESP 4MOTION MK60 0102
Revision: 00H13001
Coding: 0004744
Shop #: WSC 01279 785 00200
VCID: 72C50EB1143F
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 BJ HW: 1K0 907 044 BJ
Component: ClimatronicPQ35 090 0909
Revision: 00090016 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 70C104B91A33
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000006157878
Coding: E68F8F2700041500001400001400000000087B075C
VCID: 2B7BD3D5F395
Part No: 1K2 955 119 E
Component: Wischer 250906 020 0501
Coding: 00038805
Shop #: WSC 01287
Part No: 1K0 955 559 AB
Component: RLS 250906 020 0103
Coding: 00207646
Shop #: WSC 01287
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 5K AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D06Z7NI
Coding: 0013643
Shop #: WSC 01269 785 00200
VCID: 6CF910C9361B
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BD HW: 1K0 953 549 BD
Component: J0527 036 0070
Coding: 0002022
VCID: 75CF35AD6551
Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K6 920 863 B HW: 1K6 920 863 B
Component: KOMBIINSTRUMENT VDD 1610
Revision: V0003000 Serial number: VWZ7Z0F8163369
Coding: 0007703
Shop #: WSC 01649 959 58089
VCID: 3041C4B9DAB3
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 3100106A0905D3
Coding: FD0F030207000001
Shop #: WSC 16490 959 95524
VCID: 2C79D0C9F69B
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 109
Mileage: 61817 km
Time Indication: 0
Date: 2000.00.00
Time: 11:10:35
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 F
Component: Haldex 4Motion 0115
Coding: 0000001
VCID: 3041C4B9DAB3
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 1610
VCID: 3041C4B9DAB3
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 005 0968
Coding: 0000564
VCID: 3851FC9932C3
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.141 H07 1806
Shop #: WSC 00000 028 00001
VCID: 354FF5AD25D1
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AJ
Component: KSG 0401
Coding: 01C802087F2D8405485AC69010CC
Shop #: WSC 21010 822 83252
VCID: 78D13C997243
Part No: 1K0 951 605 D
Component: LIN BACKUP HORN H07 8003
Part No: 1K0 951 178
Component: Neigungssensor 001 0101
Component: Innenraumueberw.001 0101
Address 47: Sound System Labels: 3C0-035-456.lbl
Part No: 1K6 035 456 A
Component: 08K Audioverst. 0005
Revision: 00003000 Serial number: 00000000009103
VCID: 2A75D6D1FC6F
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0000564
VCID: 3957F99D09C9
Address 55: Xenon Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000004
VCID: F4C988A9EE2B
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 195 D
Component: Radio BVX 012 0032
Coding: 0010010
VCID: 27732FE5EF7D
End ---------------------------------------------------------------------
Octavia vRS TDi DSG MY10 - RD Technik tuned
Polo 9N3 1.9TDi
Snap. Mine shows that too and I was going to send my log off to Ross-Tech but have not found time to do it yet.
Also when I change the number of flashes the indicator gives from 3 to 5 - it stays on 3, even though log shows 5. Need to investigate that further.
Mark 7.5 2018 White Golf R with Driver Assist & Dynaudio packages.
Polo 77TSI White Comfortline DSG - partner drives
We are a VW family
All good....nothing seems to be not working...so not really too bothered...I am putting in the new canbus in a few weeks when the RNS510 comes so I will see if something else comes up then when reprogrammed.
I do find it funny though how it gives it a fault priority of 1!! when it seems to affect nothing![]()
Your gateway has been incorrectly coded to say you don't have a radio. If you look at your module listing you will see it says 'radio - status not registered'. Basically this is telling you that the car knows you it has a radio but for some reason it's been told that it doesn't (or something around those lines). Why that is I can not tell you.
MY11.5 MKVI Volkswagen Golf GTI | 5 DR | Deep Black Pearl | Manual | Bi-Xenons (Incl LED's) | 18" Detroits | Black Leather Package | RNS510 Sat Nav | MDI | Bluetooth | R Tails | P3 Gauge
Thanks OzTrekker. Would have been awhile before I thought of that. Didn't have to do that on the Polo. Now to decide on whether 5 is too long or not - give it a week or so and then compare to 4 flashes.
We are a VW family
Yeah i think it may be the radio thing too.
