Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: anyone with VAGCOM /VCDS in Newcastle area?
    Oct 2021
    Newcastle,NSW
    Hi Lucas, Thanx for reply my mechanic tells my that VCDS can disable the - not just clear
    Quote Originally Posted by Bettle69er View Post
    VCDS will be able to do an output test and adaptation to ensure the little manifold flap motor is working etc, but these normally fail because as they wear out the flap moves too far and then gets stuck. The “fix” is to install that metal bracket which stops the flap from being able to move past the point of no return.
    I very much doubt you will be able to fix this code for good without installing the part. Im happy to clear the code for you but no doubt it will come back.
    Oct 2021
    Newcastle,NSW
    Hi Lucas would you be willing to run a scan - am interested in any transmission faults, am happy to pay
    I'll send you a private message with my details.
    Mar 2015
    Newcastle, NSW
    Im in Newcastle and have both Carista and VCDS.
    Hey mate PM sent.
