Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: anyone in Melbourne that can help retrieve SKC?
    May 2015
    Question anyone in Melbourne that can help retrieve SKC?
    Looking for someone who has the cable for doing this. I'm looking to replace my dash cluster and can't more forward unless i can pull the SKC.
    I'm having troubles using the vag tacho 3.01 cable i got from e-bay in that it tries to connect to VDO old or new but then the option to read PIN is greyed out . i can successfully connect with "immo box Audi / VW GOL (megamos)" but when trying to get the pin i get an error saying wrong immo.
    if anyone can help that'd be great
    Jan 2014
    Mt Martha, Vic
    What immo is you Audi?
    Sent from my Nexus 9 using Tapatalk
    Using Tapatalk
    May 2015
    immo 3 (correct me if i'm wrong)
    Attached Thumbnails Attached Thumbnails anyone in Melbourne that can help retrieve SKC?-jpg
    Jan 2014
    Mt Martha, Vic
    My understanding, which could be wrong, is that you cannot read the pin with immo 3 or immo 4, especially with a cheap eBay knock off cable.
    I know that doesn't really help you. I have a proper Vagcom and cannot access immo 3 & 4. Needs to go to a dealer.
    You could try The Retrofitters they should be able to either advise you or read the pin for you, at a cost of course.
    Good luck.
    Saying that think your immo 2, based on that being the last digit on your instrument code.
    Using Tapatalk
    May 2015
    LOL
    dammit thought i was getting somewhere there
    will have a look at the retrofitters. thanks
    Jan 2014
    Mt Martha, Vic
    If it is immo 2 you should be able to read the codes you need. There is a good forum post on this somewhere I will see if I can find it for you....
    Using Tapatalk
    May 2015
    I have read a couple of things where an aftermarket stereo may stop obd communications from working properly so I will need to try that with putting the original Head unit back in...
    Otherwise thanks so much for having a look Horace01
    See I'm reading this
    Immobilizer - Ross-Tech Wiki
    That says if both VIN and 17 digit are showing in the extra field = immo 3???
    Oh yeah forgot to mention this is for an Audi S3 but shouldn't matter right??
    Jan 2014
    Mt Martha, Vic
    This thread on vwvortex has some good info on coding VWVortex.com - DIY: hi-line cluster
    Using Tapatalk
    VAGTacho sucks for Audi's.
    Where about in Melb are you located, I might know someone who can do it for you. Or if you sent the cluster to me I could do it but that's not that convenient.
    You might find that the dealer will be useless to get you the PIN as they don't see it on their system, I don't think that they can even access it anymore.
    May 2015
    stupid VAGTacho! LOL
    AALocksmiths - i'd rather send to adelaide than to the UK where the guy who sent me a new screen has been supporting me to no end!
    (yes, i replaced the screen for a new one and the guy doing it stuffed it, one of the tracks on the PCB lifted, leaving me with permanent blank line in the middle and one of the speedo lights kaput - hence looking into options)
    I'm in the SE of melbourne but can travel or even send the boards around by mail. the car isn't being used at the moment so i'm in no rush and any help would be great!
    so if i get a replacement tacho (i'm looking at a UK one which has MPH on it but have been told that i should be able to program it for Australia then just use my dials) you/or your melbourne contact can pull SKC from both?
    i have a ross-tech VCDS so can do the rest of the programming from there
