The_Hawk: Hi again - First, I must apologise if I have not been sufficiently clear - English is a cow of a language in which to express any assertion and alas it has a second disadvantage of being it my second language!!
So, to be clear- I'm not saying that there is anything wrong with HEX+CAN cables. But - and there is always a but - the design of HEX+CAN cables must be some where around 20 years old now and as was demonstrated in the "Ross-Tech" firmware patch that was needed to fix the compatibility problem with MIBII, the design of HEX+CAN cables is approaching its limit as VW's control modules become ever more complex and ever more up-to-date!!HEX+CAN versus HEX-NET - A SPEED TEST!!As far as my claim about the relative performance of HEX-NET versus HEX+CAN (still a good cable), perhaps an easy way to demonstrate this is through the simple process of an autoscan.
So Here's the broad basis of my speed-test: I've just completed two auto-scans on my mk7: one with my HEX-NET cable and again with my HEX+CAN cable. For each run, I have tried to keep all the variables the same (i.e. same car, same laptop, same RT version software) - the only difference was the cable.
Unfortunately, VWW's word limit policy won't allow me to post-up the full results of 2 x autoscans (in the one post), but here's a cut-down section of the auto-scan result using my HEX+CAN cable
And here's a cut-down section of the auto-scan result using my HEX-NET cableCode:Monday,19,December,2016,18:31:56:03521 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 16.8.4.2 (x64) Data version: 20161129 DS267.0 www.Ross-Tech.com VIN: License Plate: SPEED TEST Mileage: 26276km-16327mi Repair Order: hex can -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: AU (5Q0) Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F VIN: Mileage: 26276km-16327miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 End-------------------------(Elapsed Time: 03:23)--------------------------
The important part of the auto-scan is the last line. HEX-NET was almost three times as fast as HEX+CAN in polling the 14 x control modules!Code:Monday,19,December,2016,18:36:16:16808 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 16.8.4.2 (x64) HEX-NET CB: 0.4323.4 Data version: 20161129 DS267.0 www.Ross-Tech.com -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: AU (5Q0) Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F VIN: Mileage: 26276km-16327miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 End----------(Elapsed Time: 01:13, VBatt start/end: 12.0V/12.0V)-----------
OK- the difference between 3 minutes and 1 minute isn't much in terms of actual elapsed time - I hear you saying! Very true, but it does mount-up!
But the real performance difference with HEX-NET becomes abundantly clear when completing adaptation channel maps for control modules with large channel-count. Here's a god example with the BCM from my car which has a channel count of about 1,800 (and this is for a mid-level BCM)
Again, I can only post a cut-down portion of the admap because of the word-count limit! Note a previous version of RT software was used for this admap
Yes- it's true: Just 01:42 to poll every possible channel in the BCM and to return about 1.800 entries - man, my HEX-NET runs like a cut-cat!!!Code:;SW:5Q0-937-084-N HW:5Q0-937-084-N --- Cent. Elect. ;Component:BCM MQBAB M H14 0106, Coding:03001842C24102FB0FA4400000040308100A000000000000000000000000 ;EV_BCMCONTI,010001,EV_BCMBOSCH_VW37.rod ;Thursday,15,September,2016,22:30:46:16808 ;VCDS Version: Release 16.8.2 (x64) Data version: 20160902 DS256 ;VCID: 43C68A64CAD4705AE8-8016 IDE00002-Transport mode,active IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,not active IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,0 Elapsed Time: 01:42
Thanks for all that. I figured you meant it was faster to read stuff but I didn't really expect quite that much faster!
That would make the decision to buy one over the other that much harder (given the limits of the WiFi version)... but speed is very nice.
kamold: I'm getting very nervous responding to another moderator (only kidding)!!
I must agree with the underlying sentiment in your reply - which is (I guess) that value is in the eye of the purchaser!
HEX-NET cables are not inexpensive (even the limited VIN version is expensive). Whether the cost is worth the purchase is ultimately a personal decision about "value". The decision to buy is made more stark if the potential buyer already has a perfectly good cable!
In my case, a unique set of circumstances arose which resulted in a value proposition that was impossible to ignore! Best decision that I have ever made - to get my HEX-NET!
Fair point about adaptation channel Maps Don.
Not owning an mqb platform vehicle my controllers have far fewer channels.
