Hi All,
My 2015 MK7 Golf R has gone through so many AFS Cornering Halogen bulbs over the years so i decided to purchase some LED version H7s. They were meant to be Canbus Error Free but suprise suprise they were not. Now with a free set of LED bulbs thanks to a refund im trying to see if i can get these to work.
Can i VCDS out the error and keep them working in the car. Im aware the MK7.5 does have LED cornering bulbs (yes its a new headlight unit) but there may be a way to code the ECU into thinking my LED bulbs are ok.
The do work at first every time i turn the car on but within 10 seconds the error code hits and they are cut off for the remainder of the drive.
Any advise would be great, i am cable equipped if someone is willing to help.
Thanks all.
Not sure if it's physically possible - but how about a non-coding solution: use shunt resistors to trick the module into thinking that the lamps are still halogen?
Lots of suppliers have these resistors (they are heaters, really) - just Google "CANbus error free resistor" and pick one to suit the LED specs and the base connector.
