Results 31 to 36 of 36
Thread: ACC Retrofit Advice Please for Golf MK7
  1. #31
    Mornington Peninsula, VIC
    @MIG: yes, I understand how a legit GeKo account and ODIS access can provide OP a way of "CP matching" his new hex13 module - but simply having J2434 (with, or without an out-of-date VCDS device) ain't going to do it!!! Hence my intrigue.
    Also, thanks for the info on the 7NO chassis radars (I didn't know this) - but I still haven't heard that anyone had managed to hack a MQB platform version radar (Why would Bosch continue to leave the debug header open on the MCU on these later modules?)
    ODIS supports J2434 devices. Is there some technical requirement that's missing? My understanding is that this is how independent shops have access to Geko, ODIS-S 10.0.0 | ODIS-E 14.1.0 | AUTEL J2534 - YouTube
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
  2. #32
    brisbane
    thanks for the feedback gents, i have a minor update with component protection now removed...
    i used the passthru dongle and access to odis by paying $40 for a single 1 hour use from these guys...
    VW GEKO ODIS Online Login Account
    only error remaining is linked to having an android head unit...
    Friday,01,March,2024,18:14:36:54062
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 23.11.0.0 (x64)
    Data version: 20231027 DS351.0
    Ross-Tech: Home
    VIN: WVWZZZAUZFW270452 License Plate: INK10
    Mileage: 178704km-111041mi Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 08 09 10 13 14 15 16 17 19 32 42 44 52 55 5F A9
    VIN: WVWZZZAUZFW270452 Mileage: 178704km-111041miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    13-Auto Dist. Reg -- Status: OK 0000
    14-Susp. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    32-Differential Locks -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    A9-Struct. Borne Sound -- Status: OK 0000
    Address 01: Engine (J623-CHHA) Labels:. 06K-907-425-V1.clb
    Part No SW: 5G0 906 259 HW: 06K 907 425 B
    Component: 2.0l R4 TFSI H13 0010
    Revision: --H13--- CVN: 584B723D
    Coding: 091D00324464050B2000
    Shop #: WSC 01357 011 00200
    ASAM Dataset: EV_ECM20TFS0215G0906259 001014
    ROD: EV_ECM20TFS0215G0906259.rod
    VCID: 6BD5C38F8256DEC906-803E
    VINID: 9E69EAAAA465A969C21C0105082C00D17E
    No fault code found.
    Readiness: 1010 0001
    Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
    Part No SW: 0D9 300 020 G HW: 02E 927 770 AQ
    Component: DQ250-6V MQB H53 4520
    Revision: 03253104 Serial number: TFK01502080055 CVN: 0000B2F1
    Coding: 0014
    ASAM Dataset: EV_TCMDQ250021 001001
    ROD: EV_TCMDQ250021.rod
    VCID: 1939C947184A9C5924-804C
    Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
    Part No SW: 3Q0 907 379 Q HW: 3Q0 907 379 F
    Component: ESC H42 0610
    Revision: 00000000 Serial number: 60385000000728
    Coding: 01FA93A15427296C077B060541C56980C92A94E0608296F718 4250B9C209
    ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
    ROD: EV_Brake1UDSContiMK100IPB_034.rod
    VCID: 489F5C03F360D5D14B-801C
    Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
    Part No SW: 5G0 907 044 BC HW: 5G0 907 044 BC
    Component: Climatronic H03 1001
    Revision: 00001K08 Dataset Number: 0000
    Coding: 00120004200100001005000012101400
    ASAM Dataset: EV_ACClimaBHBVW37X 003018
    ROD: EV_ACClimaBHBVW37X_003_VW37.rod
    VCID: 69D9B98788AACCD974-803C
    Fresh air blower control module (front):
    A/C pressure/coolant temperature sensor:
    Air quality sensor:
    Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
    Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
    Component: BCM MQBAB H H18 0137
    Serial number: 01011504503381 Dataset Number: 5G0063v____ 0001
    Coding: 03001A42C24122FB0BA44080B10C0728100000000000000000 0000000000
    ASAM Dataset: EV_BCMCONTI 013000
    ROD: EV_BCMBOSCH_013.rod
    VCID: 000F84239BD02D91C3-8054
    Wiper motor control module:
    Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
    Component: WWS 150202 042 0551
    Serial number: 150207073710
    Coding: 0E4DDD
    Rain/Light Recognition Sensor:
    Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
    Component: RLHS 037 0059
    Serial number: S5Y15M02D16H19M45S23
    Coding: 00A8DD
    Anti-theft alarm system sensor:
    Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
    Component: Sensor, DWA 005 0315
    Serial number: 000000000ZY1502342Z9
    Alarm horn:
    Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
    Component: Sirene, DWA 004 0311
    Serial number: 00000000000061644739
    Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
    Part No SW: 5Q0 919 294 E HW: 5Q0 919 294 A
    Component: PARKHILFE 8K H03 0048
    Revision: -------- Serial number: 39391504217542 Dataset Number: 5G0039v__A_ 0020
    Coding: 0031151011
    ASAM Dataset: EV_EPHVA18AU3700000 002024
    ROD: EV_EPHVA18AU3700000_002_VW37.rod
    VCID: 3D713DD7ACA28079E8-8068
    Address 13: Auto Dist. Reg (J42 Labels:| 5Q0-907-567.clb
    Part No SW: 5Q0 907 567 J HW: 5Q0 907 567 J
    Component: ACC3 H09 0395
    Serial number: 23061375030055 Dataset Number: 5g0114v____ 0014
    Coding: 001E1300FE030B
    Shop #: WSC 00028 028 00023
    ASAM Dataset: EV_ACCBoschMQB 001022
    ROD: EV_ACCBoschMQB_VW37.rod
    VCID: 428B4E2BD55CFF8195-8016
  3. #33
    brisbane
    Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
    Part No SW: 5Q0 907 376 HW: 5Q0 907 376
    Component: DAEMPFUNGS-SG H16 0115
    Serial number: 19011541350032 Dataset Number: 5G0532v____ 0022
    ASAM Dataset: EV_DRCONTITEMIC 001019
    ROD: EV_DRCONTITEMIC_VW37.rod
    VCID: 76E3E2FBC9141321E9-8022
    Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
    Part No SW: 5Q0 959 655 D HW: 5Q0 959 655 D
    Component: AirbagVW20 014 0385
    Serial number: 003F6R0G6FAC Dataset Number: 5G0003v____ 0096
    Coding: 98CCC000000000005C00000000C800000065
    ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
    ROD: EV_AirbaVW20SMEVW37X_VW37.rod
    VCID: 41894127D05AE4998C-8014
    Crash sensor for side airbag: driver side:
    Subsystem 1 - Part No SW: ----------- HW: 480 001 102 15
    Component: SideSensor_Df 001 0887
    Serial number: 3576700000060274E21L
    Coding: 2D2D2D
    Front Passenger's Side Airbag Crash Sensor:
    Subsystem 2 - Part No SW: ----------- HW: 480 001 102 15
    Component: SideSensor_Pf 001 0887
    Serial number: 3586700000036134E21K
    Coding: 2D2D2D
    Rear Side Airbag Crash Sensor (on driver's side):
    Subsystem 3 - Part No SW: ----------- HW: 480 400 602 15
    Component: SideSensor_Dr 001 6149
    Serial number: 3516502A1196FF53D06K
    Coding: 2D2D2D
    Passenger side rear thorax airbag crash sensor:
    Subsystem 4 - Part No SW: ----------- HW: 480 400 602 15
    Component: SideSensor_Pr 001 6149
    Serial number: 3526502BB196FF54804Q
    Coding: 2D2D2D
    Crash sensor for front airbag: driver side:
    Subsystem 5 - Part No SW: ----------- HW: 480 400 502 15
    Component: FrontSensor_D 001 6149
    Serial number: 3556502C5192BC734039
    Coding: 2D2D2D
    Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
    Part No SW: 5Q0 953 521 P HW: 5Q0 953 569 A
    Component: Lenks.Modul 075 0175
    Revision: FF032032 Serial number: 20150212400803
    Coding: 0410
    ASAM Dataset: EV_SMLSVALEOMQB 001015
    ROD: EV_SMLSVALEOMQB.rod
    VCID: 3F8D47DFA6AE9269FA-806A
    Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
    Part No SW: 5G1 920 756 HW: 5G1 920 756
    Component: KOMBI 301 4310
    Coding: 27AD09083F80000800802A011400000000000000
    Shop #: WSC 00046 412 12345
    ASAM Dataset: EV_DashBoardVDDMQBAB 009043
    ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
    VCID: 6ADBC68B8DACC7C17D-803E
    Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
    Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 F
    Component: GW MQB High 128 1204
    Revision: -------- Serial number: 0003097448 Dataset Number: 5G0067v____ 2011
    Coding: 030100342F085900FF00026B9C0F0001000105000000000000 0000000000
    GVL: 01543C5000000000400C90000000CC00000000000000000000 00000000000000
    ASAM Dataset: EV_GatewLear 011020
    ROD: EV_GatewLear_011.rod
    VCID: 72EBDEEBA57C0F01C5-8026
    Generator:
    Multifunction steering wheel control module:
    Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
    Component: E221__MFL-DC1 H06 0038
    Serial number: 29140000427050064121
    Coding: 2DFFFF
    Battery Monitoring Control Module:
    Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
    Component: J367-BDMHella H04 8050
    Serial number: 4199495603
    Address 32: Differential Locks (J492) Labels:* 0CQ-907-554.clb
    Part No SW: 0CQ 907 554 E HW: 0CQ 907 554 E
    Component: Quersperre H52 8040
    Serial number: HA1-00002.12.14 Dataset Number: v1260x015G0 0000
    Coding: 0001
    ASAM Dataset: EV_LockElectHA1VW37X 001001
    ROD: EV_LockElectHA1VW37X.rod
    VCID: 479D5F3FFE7EDAA942-8012
    Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
    Part No SW: 5Q0 959 593 D HW: 5Q0 959 593 B
    Component: TSG FS 020 0028
    Serial number: 270115BAP14609 Dataset Number: 5G0222v____ 0061
    Coding: 003E02208001040000000000
    ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
    ROD: EV_DCUDriveSideEWMAXCONT.rod
    Rear Driver Side Door Control Module:
    Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
    Component: FOND_FHSG_DRV 005 0005
    Serial number: 00000000000005296446
    Coding: 0D0000
    Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
    Part No SW: 3Q0 909 144 H HW: 3Q0 909 144 H
    Component: EPS_MQB_ZFLS 505 5061
    Dataset Number: 5G0074v____ 0976
    Coding: 8103
    ASAM Dataset: EV_SteerAssisMQB 012140
    ROD: EV_SteerAssisMQB_012_VW37.rod
    VCID: 377D2FFF8E9EAA2932-8062
    Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
    Part No SW: 5Q0 959 592 D HW: 5Q0 959 592 B
    Component: TSG BFS 020 0028
    Serial number: 060215BB515856 Dataset Number: 5G0157v____ 0057
    Coding: 003E02208E01040000800000
    ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
    ROD: EV_DCUPasseSideEWMAXCONT.rod
    Rear Passenger Door Control Module:
    Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
    Component: FOND_FHSG_PSG 005 0005
    Serial number: 00000000000005331087
    Coding: 150000
    Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb
    Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
    Component: AFS-ECU H07 0090
    Revision: -------- Serial number: -------------- Dataset Number: 5G0036v____ 0021
    Coding: 029603000B000200
    ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
    ROD: EV_HeadlRegulVWAFSMQB.rod
    VCID: 408F4423DB50ED9183-8014
    Left Headlamp Power Output Stage:
    Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
    Component: LeiMo links H01 0002
    Coding: 2E0000
    Right Headlamp Power Output Stage:
    Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
    Component: LeiMo rechts H01 0002
    Coding: 2E0000
    Address 5F: Information Electr.
    Cannot be reached
    Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
    Part No SW: 5G0 907 159 HW: 4H0 907 159 A
    Component: SAS-GEN 2 H06 0014
    Serial number: 150118201063
    ASAM Dataset: EV_SoundActuaGen2AU64X 003010
    ROD: EV_SoundActuaGen2AU64X.rod
    End-------------------------(Elapsed Time: 04:43)--------------------------
  4. #34
    brisbane
    It looked like it might work when i first drove it...
    but it wasn't long before i got the dreaded ACC and front assist no sensor view warning...
    I'm hoping its linked to the alignment settings and i'm planning on following this thread to try and resolve it...
    2014/15 MK7 Golf, MQB, ACC system faults | Ross-Tech Forums
    Found solution to ACC Not Available / Radar calibration needed (with VCDS) | GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum
    MK7 ACC radar adjustment without calibration board | GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum
  5. #35
    Great work!
    Yep, before I got my one dialled in, it was only 50m before it cut off.
    Check the error log and measuring values for angle. If you can park on level ground, use your phone spirit level to get the up-down adjustment right, then tweak the left-right.
    If you have a laser level, getting the little mirror in line with the car's thrust angle is a good place to start.
  6. #36
    brisbane
    Quote Originally Posted by MIG View Post
    thanks for the advice mate, I'll definitely start with the level on my phone...
    I'm not sure what you mean about getting the little mirror in line with the thrust angle so would appreciate anymore detail or other tips you have please...
