"Byte 24 - Bit 18 (with ACC Stop and Go)" I think you mean Byte 24 - Bit 3 & Bit 4! Stop-and-Go functionality is sometimes called "traffic jam assist". This facility is in the newer ACC systems and it integrates other driver assistance technologies including lane keeping assist, forward collision warning, pedestrian detection, and automatic emergency braking. I very much doubt that adding the additional functionality will help in your case!!
Byte 26 - Bit 50 (with multilink suspension) I think you mean Byte 26 - Bit 4 & Bit 6. According to the long-code string on the ABS module - this car is factory fitted with a fixed-beam rear suspension. Multi-link suspension is normally fitted to Golf GTI/R models. I assume this change is related to retrofitting the bi-directional wheel speed sensors
"Byte 29 - No Change (appears unrelated to ACC)" No comment!
"replace the two rear wheel speed sensors with part number WHT003858A..." Probably a good idea (I talked about this in an earlier reply)
