Results 11 to 20 of 36
Thread: ACC Retrofit Advice Please for Golf MK7
    brisbane
    Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
    Part No SW: 5Q0 907 376 HW: 5Q0 907 376
    Component: DAEMPFUNGS-SG H16 0115
    Serial number: 19011541350032
    ASAM Dataset: EV_DRCONTITEMIC 001019
    ROD: EV_DRCONTITEMIC_VW37.rod
    VCID: 76E3E2FBC91413396B-8022
    No fault code found.
    Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
    Part No SW: 5Q0 959 655 D HW: 5Q0 959 655 D
    Component: AirbagVW20 014 0385
    Serial number: 003F6R0G6FAC
    Coding: 98CCC000000000005C00000000C800000065
    Shop #: WSC 01357 011 00200
    ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
    ROD: EV_AirbaVW20SMEVW37X_VW37.rod
    VCID: 41894127D05AE4810E-8014
    Crash sensor for side airbag: driver side:
    Subsystem 1 - Part No SW: ----------- HW: 480 001 102 15
    Component: SideSensor_Df 001 0887
    Serial number: 3576700000060274E21L
    Coding: 2D2D2D
    Front Passenger's Side Airbag Crash Sensor:
    Subsystem 2 - Part No SW: ----------- HW: 480 001 102 15
    Component: SideSensor_Pf 001 0887
    Serial number: 3586700000036134E21K
    Coding: 2D2D2D
    Rear Side Airbag Crash Sensor (on driver's side):
    Subsystem 3 - Part No SW: ----------- HW: 480 400 602 15
    Component: SideSensor_Dr 001 6149
    Serial number: 3516502A1196FF53D06K
    Coding: 2D2D2D
    Passenger side rear thorax airbag crash sensor:
    Subsystem 4 - Part No SW: ----------- HW: 480 400 602 15
    Component: SideSensor_Pr 001 6149
    Serial number: 3526502BB196FF54804Q
    Coding: 2D2D2D
    Crash sensor for front airbag: driver side:
    Subsystem 5 - Part No SW: ----------- HW: 480 400 502 15
    Component: FrontSensor_D 001 6149
    Serial number: 3556502C5192BC734039
    Coding: 2D2D2D
    Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
    Part No SW: 5Q0 953 521 P HW: 5Q0 953 569 A
    Component: Lenks.Modul 075 0175
    Revision: FF032032 Serial number: 20150212400803
    Coding: 0410
    ASAM Dataset: EV_SMLSVALEOMQB 001015
    ROD: EV_SMLSVALEOMQB.rod
    VCID: 3F8D47DFA6AE927178-806A
    Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
    Part No SW: 5G1 920 756 HW: 5G1 920 756
    Component: KOMBI 301 4310
    Coding: 27AD09083F80000800802A011400000000000000
    Shop #: WSC 00046 412 12345
    ASAM Dataset: EV_DashBoardVDDMQBAB 009043
    ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
    VCID: 6ADBC68B8DACC7D9FF-803E
    Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
    Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 F
    Component: GW MQB High 128 1204
    Revision: -------- Serial number: 0003097448
    Coding: 030100342F085900FF00026B9C0F0001000105000000000000 0000000000
    GVL: 01543C5000000000400C90000000CC00000000000000000000 00000000000000
    ASAM Dataset: EV_GatewLear 011020
    ROD: EV_GatewLear_011.rod
    VCID: 72EBDEEBA57C0F1947-8026
    Generator:
    Multifunction steering wheel control module:
    Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N
    Labels: 3C8-959-537.CLB
    Component: E221__MFL-DC1 H06 0038
    Serial number: 29140000427050064121
    Coding: 2DFFFF
    Battery Monitoring Control Module:
    Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
    Component: J367-BDMHella H04 8050
    Serial number: 4199495603
    Address 32: Differential Locks (J492) Labels:* 0CQ-907-554.clb
    Part No SW: 0CQ 907 554 E HW: 0CQ 907 554 E
    Component: Quersperre H52 8040
    Serial number: HA1-00002.12.14
    Coding: 0001
    ASAM Dataset: EV_LockElectHA1VW37X 001001
    ROD: EV_LockElectHA1VW37X.rod
    VCID: 479D5F3FFE7EDAB1C0-8012
    Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
    Part No SW: 5Q0 959 593 D HW: 5Q0 959 593 B
    Component: TSG FS 020 0028
    Serial number: 270115BAP14609
    Coding: 003E02208001040000000000
    ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
    ROD: EV_DCUDriveSideEWMAXCONT.rod
    VCID: 428B4E2BD55CFF9917-8016
    Rear Driver Side Door Control Module:
    Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels:
    5QX-959-81X-V1.CLB
    Component: FOND_FHSG_DRV 005 0005
    Serial number: 00000000000005296446
    Coding: 0D0000
    Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
    Part No SW: 3Q0 909 144 H HW: 3Q0 909 144 H
    Component: EPS_MQB_ZFLS 505 5061
    Coding: 8103
    ASAM Dataset: EV_SteerAssisMQB 012140
    ROD: EV_SteerAssisMQB_012_VW37.rod
    VCID: 377D2FFF8E9EAA31B0-8062
    Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
    Part No SW: 5Q0 959 592 D HW: 5Q0 959 592 B
    Component: TSG BFS 020 0028
    Serial number: 060215BB515856
    Coding: 003E02208E01040000800000
    ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
    ROD: EV_DCUPasseSideEWMAXCONT.rod
    Rear Passenger Door Control Module:
    Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels:
    5QX-959-81X-V1.CLB
    Component: FOND_FHSG_PSG 005 0005
    Serial number: 00000000000005331087
    Coding: 150000
    Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb
    Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
    Component: AFS-ECU H07 0090
    Revision: -------- Serial number: --------------
    Coding: 029603000B000200
    ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
    ROD: EV_HeadlRegulVWAFSMQB.rod
    VCID: 408F4423DB50ED8901-8014
    Left Headlamp Power Output Stage:
    Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E
    Labels: 3D0-941-329.CLB
    Component: LeiMo links H01 0002
    Coding: 2E0000
    Right Headlamp Power Output Stage:
    Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E
    Component: LeiMo rechts H01 0002
    Coding: 2E0000
    Address 5F: Information Electr.
    Cannot be reached
    Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
    Part No SW: 5G0 907 159 HW: 4H0 907 159 A
    Component: SAS-GEN 2 H06 0014
    Serial number: 150118201063
    ASAM Dataset: EV_SoundActuaGen2AU64X 003010
    ROD: EV_SoundActuaGen2AU64X.rod
    VCID: 6BD5C38F8256DED184-803E
    End-------------------------(Elapsed Time: 05:21)--------------------------
    brisbane
    just pasting this here from another website as i have a feeling it may come handy for abs coding...
    MK100 ABS Coding | Ross-Tech Forums
    Retrofitting Adaptive Cruise Control to Mk7 (oh the fun you shall have!) | VW Vortex - Volkswagen Forum
    This is an extract from the link above:
    "There's a .pdf floating around out there by "Xagico" that lists a pile of different retrofits and mods that can be done on the Mk7; it has a lot of the coding changes to be made. So that's where I started.
    In ABS coding, however, the recommendations on Byte24 ( F4 or F8 ) were not accepted by my car. (I'm guessing this is because Xagico is Spanish(?), and the European cars came with some hardware as standard that were not offered on our cars).
    Anyway, using the Somnus's spreadsheet, I was able to calculate that Byte24 on my car should be either 16 or 18; I tried 16 there and it worked. Again, YMMV, so do the math for yourself.
    Next, I changed Byte26 to F0 - if you install the new rear wheel ABS sensors first and continue to drive your car without making any other changes, you'll probably have a pile of errors on your display. Change this byte and the errors should disappear literally as you're sitting there.
    (Xagico's pdf said to change this to 50, and when I had my just the wheel sensors in my car - without swapping the ABS module - "50" made the errors go away. But once the new module was in the car, while I didn't have any errors, ACC would not work. Helpful user at ross-tech forum suggested to try "F0"....and just like that, everything, ACC worked. Not sure how he arrived at F0, but I'm glad he did.
    Lastly in Byte29, Xagico said to change it to 39, but that didn't work for me. A user over at Ross-tech's forums helping me out suggested 22 - and that one worked."
    Mornington Peninsula, VIC
    It's good to hear you got it sorted; I like to use the VCDS coding helper for these types of things and cross-check other cars' scan logs with the setup you are trying to match.
    Don't worry about any coding of the 5F unit, that's only for the menus to show up on the radio.
    With your component protection issue, you need to find someone who has access to ODIS, 5054a or vas6154 and access to geko; I know due to the right to repair stuff, some good VAG specialists have access to this now.
    There is a shady market of companies "renting" their accounts out in 15min\20min blocks, not going to recommend that here.
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    @guile: hmmm........ the coding for the ABS module in your VCDS scan doesn't make sense (it doesn't comply with your words about the changes made).
    Here's a more elucidating form of the hex03 long-code string from your SCAN report:
    Byte
    Hex Binary
    00 01 00000001
    01 FA 11111010
    02 93 10010011
    03 A1 10100001
    04 54 01010100
    05 27 00100111
    06 29 00101001
    07 6C 01101100
    08 07 00000111
    09 7B 01111011
    10 06 00000110
    11 05 00000101
    12 41 01000001
    13 C5 11000101
    14
    69 01101001
    15 80 10000000
    16 C9 11001001
    17 2A 00101010
    18 94 10010100
    19 E0 11100000
    20 60 01100000
    21 82 10000010
    22
    96 10010110
    23 F7 11110111
    24 00 00000000
    25 42 01000010
    26 00 00000000
    27 B9 10111001
    28 C2 11000010
    29 09 00001001
    As you can see - the coding values that you describe are NOT consistent with the list above. Maybe these are the pre-change coding values? If so, please post up the actual SCAN results post changes (the old long-code isn't of much value if you are describing the coding values that worked!)
    brisbane
    Quote Originally Posted by MIG View Post
    thanks mate and thanks for the reassurance regarding the 5F unit, i wondered if that would be the case. panic over...
    I've also managed to get it booked in with VW for component protection removal, lets hope i walk out of there without having to remortgage the house...
    brisbane
    thanks for the feedback Don, is there a reason Byte 14 and 22 are bold? the original coding didn't work as per the rejection photos i posted...
    I'm not sure if its linked to the fact that component protection has not been removed yet or if the coding is incorrect. I'm planning to try the revised coding as per the feedback below from another forum, Nuje on VW Vortex:
    "In ABS coding, however, the recommendations on Byte24 ( F4 or F8 ) were not accepted by my car. (I'm guessing this is because Xagico is Spanish(?), and the European cars came with some hardware as standard that were not offered on our cars).
    Quote Originally Posted by guile View Post
    ...........is there a reason Byte 14 and 22 are bold? the original coding didn't work as per the rejection photos i posted...
    NO- my bolded Byte 14 and Byte 22 was not relevant to your purpose (which is why I didn't address these Bytes in my response). I simply wanted to confirm (to myself) that the sequence in these Bytes was consistent with the Ross-Tech coding spreadsheet - which says that Byte 22 is the mirror of Byte 14.
    But, since you have raised it, from my table:
    • Byte 22 = 10010110
    • Byte 14 = 01101001
    As you can see - the 2 x Bytes are indeed mirrored!!
    Again "NO". Component Protection errors do NOT affect coding values. As you have observed, modules with CP errors can have both their adaptation channel and long-code values changed without restriction! CP errors ostensibly limit the way that the modules operate-rather than how they are coded (and modules with CP can NOT correct Basic Setting errors)
    hmm...... without intending any offense to the original Vortex authors - I would caution against modifying Bytes based on a suggestion to change the entire hex value.
    To explain- as you will be aware, a Byte consists of 8 x Bits. It's important to acknowledge that each of these 8 x Bytes is independent - meaning that while a set of Bits might be associated with a particular function, each individual Bit is a separate (software) switch that has it's own singular purpose.
    The ABS module on your car has 30 x Bytes - so this module has 240 separate (software) switches in its long-code string.
    Here's an example of my concern about making whole-of-Byte changes as per the Vortex suggestion: Consider Byte 24 - According to the Ross-Tech spreadsheet, these are the Bit descriptors:
    Byte 24
    • Bit 0 = Restart when reversing
    • Bit 1-4 = ACC Setting
      • Bit 1~4 unchecked - Without ACC, Without Front Assist, Without AEB (PR. 8T0, 8T2)
      • Bit 4 checked - Without ACC, With Front Assist, With AEB (PR. 8T0, 8T2)
      • Bit 2 & 4 checked - With ACC, With Front Assist, With AEB (PR. 8T5/8T7)
      • Bit 1, 2 & 4 checked - With ACC (Follow to Stop), With Front Assist, With AEB (MK100IPB)
      • Bit 3 & 4 checked - With ACC (Stop & Go), With Front Assist, With AEB (MK100IPB)
    • Bit 5 = PLA3.0 Installed
    • Bit 6 = PLA3.0 related
    • Bit 7 = Trailer Assist Installed
    Assume for this example that ACC is retrofitted on a car that was factory installed with- PLA2.0 (i.e. NOT PLA3.0), No trailer, No ACC, No restart when reversing. The factory value on Byte 24 on this car would be 00000000=hex00. This is the same as on your car - see my previous table
    If you followed "the recommendations on Byte24 ( F4 or F8 )" from VW Vortex - the change would mean
    • Byte 24 = F8 =11111000, OR
    • Byte 24 = F4 =11110100
    Remember that Bit 0 is the right-most digit and Bit 7 is the left-most digit in a Binary number
    So in following the Vortex recommendation- not only are you telling the ABS module to enable ACC, the change also tells the module to start operating PL3.0 AND Trailer Assist!!
    Moral of my story (which of course you can entirely ignore) = when modifying Byte values after a retrofit - ALWAYS (capital letters for emphasis) make changes to individual Bits. Or said another way =NEVER change whole-of-Byte hexadecimal values!!!
    Last edited by DV52; 25-01-2024 at 07:31 AM. Reason: corrected Binary value for F8 & F4 (missing a Bit) - thanks @guile
    brisbane
    thanks again for the info Don, i'm pretty new to this level of coding so some of the info is taking a while to sink in...
    I'll use the somnus guide to revise Bit values when I'm back home next based on the hexadecimal table below...
    Decimal.....Hex digit.....Binary code
    0...................0...............0000
    1...................1...............0001
    2...................2...............0010
    3...................3...............0011
    4...................4...............0100
    5...................5...............0101
    6...................6...............0110
    7...................7...............0111
    8...................8...............1000
    9...................9...............1001
    10.................A...............1010
    11.................B...............1011
    12.................C...............1100
    13.................D...............1101
    14.................E...............1110
    15.................F................1111
    brisbane
    Based on the above conversion chart please confirm if your codes below are missing a zero at the end:
    "If you followed "the recommendations on Byte24 ( F4 or F8 )" from VW Vortex - the change would mean
    Byte 24 = F8 =1111100, OR
    Byte 24 = F4 =1111010"
    I'm just trying to make sure i understand this correctly...
    @guile: Ooops - my bad (good pick-up on your part)
    Yes, indeed - I failed to make the Binary equivalent an 8 x Bit number. (now fixed - thanks)
    As for your efforts to convert Hexadecimal to Binary (Hex2Bin) and vice-a-versa (Bin2Hex) - there are lots of websites that will do this automatically - like HERE
