Results 1 to 6 of 6
Thread: Tyre pressures 17" alloys
    Aug 2012
    Does anybody know where I can find the correct tyre pressures for the 17" wheels on the Fabia vRS? Can't find in the manual or stuck yo the body somewhere?
    Thanks
    Difinity
    Jan 2009
    Check if the sticker is on the fuel filler flap.
    Erskineville, NSW
    Fuel filler flap.
    34-36psi will do the job
    Aug 2012
    Many thanks
    Difinity
    Apr 2013
    Fuel filler flap.
    +1
    I normally run about 36psi
    2012 Fabia II VRS Estate - APR stage 2 tune, Custom 2.5" turbo back full stainless exhaust with ceramic coated dump pipe, Harding Performance Cold air intake, Wagner Tuning Competition Intercooler, GFB DV+ diverter valve, Braille B2317RP battery, Eibach pro kit springs, Bilstein B8 shocks, Harding Performance F+R ARB, Super Pro bushes, Porsche 986 Boxster S front brake calipers, 330x28mm front rotors, Ferodo DS2500 front pads and Remsa rear pads, Enkei RPF1 17x8 et.35 with 235/40R17 Yokohama AD08R tyres, Maxton front splitter and Superskoda fender flares.
    Jan 2012
    that's cold too, don't fill them when they are warm.
    or at least measure them when cold, go to the servo and measure them again and add the difference. that should be close enough
