Had the same problem a few weeks ago when I picked up my VRS combi too (but i'm using andriod). First up check to make sure you have your bluetooth is enabled on your phone in your settings. I think I then only had a 2 minute window on my phone once I made it visable to other devices to make the connection. From the car side I think it is 3 minutes after you start the ignition to find your phone. Then just follow the prompts and you manual and you will be pretty close.
The next question you may have is how to get out of the phone menu. Just hold the up selector button down for like 3 seconds on the end of the right hand side wiper controls. This should get you back to the normal MFD screens.
