What the cheapest way of resetting the service indicator? - Roomster 1.9 TDi
My books: http://amazon.com/author/julianedgar
Manually using the odometer and clock buttons. Instructions should be in your owners manual. The cheapest VCDS cable will do it as well.
Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Thanks, but I can't make the book instructions work. I must be doing something wrong...
What does your book say? (I can't even recall it was in the owners manual of the Octavia). I did work out how to do it (reset it from variable to fixed accidently while stuffing about with it) & wrote it down in my service manual for the "technicians" at the dealership. Waste of time as they still forgot to do it. I dragged the service manager out to the car & showed him how.
As the others said, you can do it with (even set up whatever service schedule you want) with a VCDS cable.
Well I got it to reset, by pressing and turning the odometer button like the book says. It just wasn't clear until I next started the car that I had in fact reset it. So it can be done!
On the Superb MFD it is resettable by the owner. I was surprised also as it is usually a dealer only function.
