hi, well we took the car to the dealer and the glovebox light switch which isnt easily got to , was not fitted correctly so all is good now.
Radio and some of the dash had to be removed.
HI, we have taken delivery of a new 2012 1.2 Roomster and its a great little car , we are impressed with it so far.
We have noted the upper glove box was getting really hot and after a little investigation including closing a recording iphone in the glove box we have discovered the glovebox light does not go out.
With the glovebox open and when the door locks are activated the open glovebox light goes out.
Is this a quirky thing or a fault?
Thanks in Advance
Phil.
hi out there in Roomster land,
I just did a tyre check and found the fronts had 32psi and the back 41psi, ( first check since pick up)
the manual quotes 220bar and 210 bar.
Has anyone got any ideal setting?
Skoda Yeti 103TDI-DSG My 13,
Look inside the fuel cap, and then experiment until you're happy with the ride/wear.
Now gone.... 2012 Skoda Fabia RS
