Big update time
My new Pace Products Intercooler and radiator package are now fitted to my car. Very impressed with the final product.
Definite improvement in response, and most importantly the power not only felt stronger, but i never noticed any power loss at all, which i normally do after 3-4 WOT runs. Its most noticeable at higher speeds though.
I gave the car a really good workout after picking her up, and im pretty certain there's a notable temperature drop in the engine bay compared to normal. Granted its colder outside than before but im pretty sure its better than it was by a fair margin.
And to put the icing on the cake, not only did they wash and clean my car, after i had explained to them that my oil temps were hitting 130degrees on track and was abit worried so they also replaced my oil with Motul 300V 5W/40 oil which has a much higher temperature range than the stock oils. As well as this they swapped my coolant for Motul MoCool to help keep temperatures in check.
Here you go these are the pics of the new radiator
Stock radiator
Dimensions
28mm thick x 730 wide x 410 high = around 8.4litres
Pace Products radiator
Dimensions
50mm thick x 730 wide 410 high = around 15 litres = 78% increase B)
As you can see, its a fair bit larger than stock.
Stock IC Dimensions
80mm Tube Width
96mm Stack Height
617mm Tube Length
= 4.73 litres
Pace Products IC Dimensions
90mm tube width
145 stack height
550mm tube length
= 7.17 litres
= 35% increase :star:
Well i removed the rear bumper and the ballast weights from the car. Almost gave up as one torx screws was defeating me for about 45 minutes because i couldnt get to it well enough to crack it then unscrew.
So i removed the wheel and arch lining in the end. Job done.
I cant believe they literally just bolted 25kg of metal weight to the rear crash beam. Easy and cheap method of weight loss though
Just driven it, and it is notably improved with the back end being alot more lively. Much less understeer, definitely a bigger difference than i expected to be honest. Probably to do with the fact that they were right out behind the rear wheels that makes it so much more noticable
