looks good wonder if they would fit a polo 6r
Got these Sokie Tech (made in Taiwan) Gas Struts off eBay recently
Finally got around to getting a TORX (6) driver to get the hood hinge screw off with
Installation took about 30 minutes including stuffing around.
Here are some pics of the finished product. Shuts surely, and firmly, note I had to remove
the standard hood brace.
NOW: 2018 MY19 Kodiaq Luxury and Tech Packs: 132kW Petrol 7DSG Sunroof and Ivory Leather
HISTORY: 2012 Fabia RS (FOR SALE) ; 2013 Fabia RS (SOLD); 2015 Octavia RS 135TDI (SOLD)
SHOULD do. That's why I included close ups of each end - compare them and see?
But the seller (SOKieTech) has an e-shop on eCrater (a US based e-commerce site) with specific kits for VW - though, as you know the US doesn't get the Polo.
I got mine on eBay through a seller called alvoturk9000 - supposedly in th UK - but he sent it from Taiwan.
On a footnote, one strut held the bonnet nicely, on its own.
Sent from my ASUS Transformer Pad TF300T using Tapatalk HD
Does the fabia come with gas lift struts as standard?
Wondering if i could get a set suitable for the tiguan but it is manual lift.
No - I just fitted these myself yesterday.
In the last photo you can see where the manual strut/rod used to be.
Doesn't the Tiguan share parts with the Golf and Yeti?
Looks like the two dependant features is the bracket shape and the weight of the hood, as each damper is set to the weight of the intended vehicle...?
Try checking these out
http://sokietech.ecrater.com/c/1266708/volkswagen
and
http://www.superskoda.com/gr/Skoda/Y...od-damper-KI-R
Either one should work, but based heavily on how the hinge and fender matches the bracket in each case.
Great idea, keep to do this on a 6R Polo
I'll try to compare your pics & see if the mounting points are the same.
2006 MkV 2.0TDI -> 2005 MkV GTI -> 2008 MkV R32 -> 2013 Polo 77TSI + 2016 Mk7 Golf R Wagon
These look great!! I wonder if there's a version for the Octy...
2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
Not including hers...
Which kit did you buy from the eBay seller? I can see they've got kits for a Golf Mk3 & MkV & a Jetta - but no Fabia or Polo.
Did it come with all the mounting brackets?
