Hi
I am thinking of replacing the factory H7 bulbs in projectors headlights in my Fabia Monte Carlo as they are absolutely hopeless at night with H7 Cob Cree LED Chip but not sure what to get. Should I get 12V 84W 4000LM or 42W 3600 LM or something else?
Thank you
The projector assemblies are not set up for LED light sources. So you will most likely see no benefit what so ever.
Either go with Philips Visionplus/Extreme or maybe go down this path
The Retrofit Source | Innovative Headlight Upgrades
because that's not the most important factor in a headlight. It's the optics that focus the light that make the most difference. And the optics for optimal beam pattern is totally different between a halogen (filament), LED and a HID lamp.
Daniel Stern Lighting Consultancy and Supply
good read. but that's what a retro kit is for.
OP, been thinking of doing the same thing for my high-beam. low beam I converted to HID already.
After the reading I decided to go for Philips Visionplus/Extreme as you suggested, it all makes a sense now.
Thank you
