Yup, about 8% less. You would have got the same effect with better pads.
I'm not saying it's not worthwhile - if you combine the bigger rotors with better pads you will have a great track day setup as the improvements will add together and as you say they look better I'm just pointing out that there is a cheaper easier option for others.
Personally I don't think there is anything wrong with the stock pedal feel but with brakes you need to be comfortable that they will do the job
