That is ridiculous good luck
Is the bad fuel their excuse to attempt to make you pay for the injectors under warranty.
Dealership scanned the engine light which was logged as a misfire but apparently they cant tell which cylinder it was?
Cars due for 60k service in bit over a 1000km so apparently no point playing with sparkplugs/compression testing now.
Heres a few year old video of the car sounding like a trabant
https://youtu.be/RS-1uAagzUk
B6 Passat Wagon No KESSY
The strict advice I had from VW/Skoda Australia is that the car was not to be driven if the ECM light came on. They said : call the tow truck.
If you have an ECM issue, they must check compression - if they'd pulled the head on mine earlier, I probably would not have blown a piston...
Difinity
The book says you can drive on yellow light
Sent from my LG-H815 using Tapatalk
The advice in mine was to turn the car off and call Skoda Roadside Assist.
Yours does sound broken though...
Difinity
That video was from july 2013car had between 5-10k on the odo back then
Wow
Difinity
