Results 11 to 20 of 21
Thread: Dashboard lights too bright
    Pacific Paradise QLD
    Quote Originally Posted by Jake02 View Post
    Have you tried accessing through the radio? My brother and I test drove a Golf6 90TSI (with the RCD310 audio system - same system as the Fabia/Roomster range/Yeti 77TSI/Octavia 90TSI/77TDI) a few weeks ago and when trying to find the Bluetooth set up in the radio it had "screen brightness", perhaps this dims the panel too? Other than that, what a bloody stupid oversight!
    That normally sets the RADIO screen brightness
    Mar 2011
    Lavers Hill Vic
    I chased this up before buying the car - you definitely can't adjust the dash brightness on Fabias.
    Bloody silly isn't it.
    We drove one into the dealer's undercover car park (dark) and decided we could live with it, but it's not impressive is it - how much did they save - a dollar if lucky...
    We have previously rented a Ford Focus (2007 model in NZ) and found the same - no adjustment and way too bright... Current model Focus has adjustment again - must have had a few complaints...
    Dec 2008
    Sydney/Canberra
    Correct me if I'm wrong, but the ability to dim the instruments is an ADR requirement.
    Shirley there has to be some way to dim them.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jan 2009
    Send an e-mail to Skoda AU (or even Skoda UK or Skoda CZ) and ask for written confirmation.
    Seems like a strange omission to me.
    Apr 2013
    Quote Originally Posted by Umai Naa!! View Post
    Thats what I thought too. Because one of the few things that had to be done on my Jap import Silvia to get it registered in Oz was the addition of a light dimmer. Although that was 18 years ago now I would have thought the law was still the same.
    Dec 2008
    Sydney/Canberra
    Quote Originally Posted by mmmRacer View Post
    Unless you can adjust the brightness with a compatible OBD scanner? Not sure that would be a sufficient-enough loophole to not require a dimmer, though.
    '01 Beetle 2.0
    Jan 2007
    The dashboard lights dim automatically. There is a sensor on the dash monitoring light levels. If you cover it with your fingers you should see the range of the dimming.
    The light sensor on your car may be defective. Does the light dim noticeably when there is a sudden change of light, for instance, driving into a tunnel?
    Aug 2012
    Geelong, Victoria
    I thought so yes... I was driving late the other night and thought it was a bit too bright and I was not even on the highway, got a bit tiring too quickly.
    Owner and Operator of 2013 Polo GTI - Sunroof - Xenons - Reflex Silver
    APR Stage 2 Tune - HP Carbon Airbox - Jetex Stainless Cat Back Exhaust - APR I/C
    Plus a few other bits and pieces.
    Aug 2012
    Geelong, Victoria
    Where is the sensor? Suppose I could consult the manual... especially coming into the darker months.
    Quote Originally Posted by brenno View Post
    Jan 2007
    I just had another look again and can't find the sensor....oops. Must have been something else that had a visible sensor.
    If you shine a torch at the guage cluster at night I can definitely see the Maxidot and the Swing display change brightness. It looks like the guages do too, but to a lesser extent.
