thank you again
Take the oil back Its the wrong stuff Penrite Enviro+ 5w-30 is approved oil The +extra is not
Or as Brad said the correct Valvoline oil is Synpower XL-III 5w-30.
thank you again
SCA will also have a Castrol EDge & Shell Helix that are approved 504/507.
Get an OEM or german made filter. Don't trust Ryco
You had a bad experience with a Ryco filter? Where do you buy other ones (apart from a Skoda dealer)?
^ Runautoparts has MANN filters for about $25 which is about as cheap as you will find locally. MANN make the filters for Skoda/VW/Audi.
https://runautoparts.com.au/vw/audi-...-2-0-tfsi.html
Genuine are usually cheaper than Ryco anyway.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
On an older VW I had, Ryco filters didn't flow as well as OEM spec filters so the bulk of the oil would bypass the filter. Once bitten, twice shy.
As Umai says, genuine Skoda will be cheaper than Ryco anyway. SCA & Repco aren't really your best source of parts for your Skoda/VW.
I'm using UFI air / fuel / cabin filters from ebay and they appear to be OEM suppliers to VW. I think my oil filters are Mann but it might be some other German brand (I bought half a dozen).
Mann filters from Run Auto appear to be good value but even the dealership ones are only around $30 last time I looked.
Just updated my previous post with a link to the oil filter you need at Run Auto Parts. This filter suits the 1.8 and 2.0 TSI engines.
All good advicethanks Bard, Umai and Lucas... I learn so much from these forums
2009 Skoda Superb Sedan - 3T ELEGANCE DSG FWD 7 Speed - 148kw 290nM (thank you Northside Eurpopean Mitchell ACT 02+ 6241 1111) 1.8 TSI...114,987km
Plugs changed... the NGKs were a little "fuzzy" on the ends.. seems a while since the car saw new plugs.... seems to run a little better now.. just have to wait till 12 January to get the Clutch plates replaced... then it should be all good...
