Originally Posted by
dArK5HaD0w
Shame about the indicator flashes not working for 5 instead of the current 3.
I'm tossing up between the OBDEleven or the Carrista.
hmm......... there is an in-car procedure that must be done after the adaptation channel setting is changed - you must reset the lights to factory settings in the MENU screen before the change takes effect. Did you do this?
