Results 1 to 10 of 56
Thread: Vcds changes
    Apr 2016
    Quote Originally Posted by ope126 View Post
    Whenever we were in Controller A5 (07 - Coding) it would not accept without stating that we needed to exit / re-try or attempt to manually input.
    Mine fails to read any coding for Controller A5 as well. It comes up all zeros.
    Quote Originally Posted by blueSup View Post
    blueSup: your observation regarding the Frt Sens. Drv. Assist control module @ address hexA5 may be because the module is correctly reporting a zero sequence for the code-string.
    I'm not sure about the Skoda Superb, but the latest generation BCM for both the Golf mk7 and Audi A3 (both also built on MQB platform) similarly report a zero sequence for their code string. In these modules, the boffins @ VAG have transferred the software switches that were previously in the code string to adaptation channels.
    Might be worth making an admap for the module and checking if the adaptation channel names refer to previous code switches.
