Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 56
Thread: Vcds changes
  1. #41
    Jul 2010
    What is "traffic info" about?
    Shame about the indicator flashes not working for 5 instead of the current 3.
    I'm tossing up between the OBDEleven or the Carrista.
  2. #42
    Aug 2013
    Quote Originally Posted by dArK5HaD0w View Post
    Traffic info shows traffic incidents on your Columbus. Things like congestion, slow traffic, accidents, road works, etc... Service is provided by SUNA and transmitted over FM. If enabled, Columbus will take traffic incidents into consideration when calculating your route. I have found it to be useful sometimes, others said it is not that accurate.
    Sent from my LG-H990 using Tapatalk
  3. #43
    hmm......... there is an in-car procedure that must be done after the adaptation channel setting is changed - you must reset the lights to factory settings in the MENU screen before the change takes effect. Did you do this?
  4. #44
    Jan 2017
    melbourne
    Nope, on the obdeleven ,it just says change value to 0-3. I changed to 5 and still did 3 times, then I change back to 3
  5. #45
    Aug 2013
    I was reading about "pedestrian assist" in VW and Skoda... Is that enabled in Australia?
  6. #46
    Aug 2013
    I have enabled Traffic Sign Recognition, using the instructions from the Briskoda thread, but it wouldn't work, the maxidot was showing "no data available for the area.
    I managed to get it to work by changing the adaptation of "Road sign detection fusion mode" in A5 to Road Sign Detection.
    I'm still not sure why it wasn't working before? is the Australian navigation data not compatible with TSR?
    Anyone else had the same issue?
    I'm going to keep it on for a while to see if it is useful or not.
    EDIT: reading more about fusion mode, it seems this is a known issue in Australia, TSR in fusion mode is not allowed here.
  7. #47
    Jan 2017
    melbourne
    mine has same problem,TSR works ok now, just an \ error message' dynamic road sign display currently restricted' pop up everyday. I just leave as it is then.
  8. #48
    Aug 2013
    Quote Originally Posted by pompom View Post
    Yes, I get that message as well... The camera also picks up the school zone 40 all the time as well... I guess aussie road sign definitions are not loaded into the camera module... I heard the Volvo XC90 and the new XC60 have TSR working in Australia properly...
  9. #49
    Jan 2017
    melbourne
    I asked on briskoda, says looks like a area problem which explains it.
  10. #50
    Jul 2010
    So I had a go today, making some VCDS changes...
    - DRL Whiskers = no luck, despite coding as per the instructions.
    - I changed the DRL to dim when side/park lights are on. previously they remained on full brightness.
    - I enabled DRLs with Rear Lights. This also turns on number plate lights, and instrument lights.
    - changed CH/LH to use fog lights instead of low beams
    - found the proper adaptation names and got HBA working - did a test drive and it works well
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
