Results 1 to 10 of 19
Thread: Tyre Wear
    Dec 2010
    Helensburgh
    Tyre Wear
    P Zeros @ 28000K with plenty of tread left. Mostly driven on open roads between 100 - 120KPH, very little suburban driving at all. The tread blocks on the front tyres are higher at the front of each block than the back, tapered so to speak and only on the inside of the tyre. Has anyone had camber issues? I was looking for a noisy tyre and when I running my hands over the tyres I noticed it. On asking the so called tyre experts all I got was blank looks for my trouble. They have been always set to the factory pressures with a Longacre digital gauge (verrrryyyy expensive) so the pressures should not be a problem. Has anyone else noticed this issue? I will put a camber gauge on it tomorrow and see what it reads but then I don't know what the stock figures are.
    Jun 2011
    Sydney NSW
    For the driven wheels, as they drive, the tread blocks are "bent" forward so the rear of the treads will have the greatest wear. Tyre pressures are not going to do much as this is more a function of the tread pattern and driving habits. For non-driven wheels, the pattern would be reversed somewhat as those wheels will be braking in the main. This is one reason why tyres are "rotated". It attempts to even out the wear.
    As you have noticed, this will not be the same over the width of the tread either and will depend on the camber. Again, setting up suspension is a compromise as it has to cover all situations. Even if you get the tread perfectly flat when straight ahead, castor changes things when the front wheels are turned as now the effective camber changes everything.
    All you can do is make sure that the wheels are correctly aligned and then look at rotating the tyres. The tyres should remain on the same side as radials do not like being driven in the opposite direction.
    Dec 2010
    Helensburgh
    As you point out caster is the big culprit on how much the camber changes when the road wheels move away from centre but I can't see it being the culprit here. As for the tread blocks bending I have not noticed this having the same effect on the other two FWD cars I have. If other Superb owners had the same tyre wear I would say it is generic to the car and not worry about it.
    Jun 2011
    Sydney NSW
    For what it's worth, on my Torana I used to run Michelin XZX and MX tyres which had a very pronounced zig-zag tread pattern and this uneven front to rear wear was always there on the rear (drive) tyres. On the front, it was was not this uneven wear, however the outside edge would always wear down first even though it had something like 0.5 to 1 degree of negative camber. The negative camber should have seen the inside wear first, so this was more to do with cornering wear than normal straight ahead wear.
    On my Hiace, all the tyres had more or less ciircumferential grooves and as a result there was no such uneven wear, but again, even though there was neutral to a very slight negative camber, the outside edge on the front tyres would always wear more than the inside. The first ones (Goodyear) did not last too long and were replaced because the tread delaminated (an acknowledged production fault), but because I was only driving around 5,000 km per year, it was outside the warranty period and so I had to get new tyres at my cost. From that point on I used Toyo tyres (HO2 and HO8 ).
    Again this shows that cornering is much more significant than straight driving, and you do not have to be driving hard for such wear patterns.
    I would get around 60,000 km from a set of tyres.
    I do know that many tyre retailers do not necessarily have the correct information on camber and castor. When I got my first set of Toyo HO2's fitted, Tyrepower did a wheel alignment and found it way out, even though the wheels were aligned at the last dealer service only around 3 months earlier. It was not anything I had done, but a major amount of adjustment had to be made to overcome what had been done at the previous wheel alignment.
    Sep 2009
    Quote Originally Posted by Ozsko View Post
    It's referred to as castellating if you are talking to a tyre person that's how you describe the problem.
    My Škoda photos here
    Flickr : Blog
    Dec 2010
    Helensburgh
    Quote Originally Posted by wai View Post
    That is from the influence of caster. Too much caster and the tyres/wheels get camber gain when cornering and the outside edges wear evenly on both tyres. Caster helps to keep the car from wandering and helps return the steering to centre when straightening up from a turn or corner.
    Dec 2010
    Helensburgh
    Quote Originally Posted by K1W1 View Post
    What causes it?
    Jun 2011
    Sydney NSW
    What causes it?
    The bending of the tread blocks.
    Erskineville, NSW
    Agree with everything else you wrote but the above is old school thought from the '80s when quality control in the manufacturing process was pretty lousy & "dirty" steel in the belts stopped the rubber bonding to the belts properly. This caused excessive belt slip in the drive tyre which when reversed caused tread separation. Goodyear were worst for it but Dunlop were a close second.
    Quite a few of the manufacturers recommend cross-rotation (and hence reversal of rotation direction). Of course, if you have symmmeical/directional tyres, then you have no choice. Reversing the rotation direction also serves to make the tyre a bit quieter for a while.
    To the OP: If your Superb is FWD & the tyres don't have direction arrows stamped in sidewalls then it won't hurt to x-rotate them. The driven wheel needs an opportunity to normalise the stresses of being the driven wheel, so unfortunately, that has to stay on the same side & go straight to the back. The rears can be crossed over: LR to RF & RR to LF. Personally, I like to do this every 7500-10,000km but if you've manged 28,000km without a rotation then every 15,000km will do at a pinch.
    If you want to wander up to Blakehurst, Id be happy to have a look at them & we can break out the jack, jackstands & rattle gun & do the job quick & easy
    Tire Tech Information - Tire Rotation Instructions
    Trivett Tyres - Tyre Tips
    Erskineville, NSW
    The first ones (Goodyear) did not last too long and were replaced because the tread delaminated (an acknowledged production fault), but because I was only driving around 5,000 km per year, it was outside the warranty period and so I had to get new tyres at my cost. .
    Goodyear tyres (and most of the other major brands) have a life of tread, pro-rata warranty for any manufacturing faults. Most Goodyear tyres come with 10/32nds of tread. If the tyre has 5/32nd left &t gets a seppo then you'll get 50% off the RRP of the new tyre. The only problem is that RRP is about 50% more than street price plus they'll try & hit you for fit/valve/balance, so once you get to about 4/32nd you are better off financially buying at street price rather than making a claim. Also, you'll find that the Goodyear branded outlets (single brand stores) are more inclined to know about & give you a claim whereas the multibrand guys try & avoid going through the claims process (they are less likely to be successful as well). What they generally do is tell you there is no claim & then put it through for themselves.
    We were very honest at our shop & knew all the batch numbers that were faulty. We'd check the s/nos on all the cars that came in & could offer new tyres at a warranty prices (we would do it cheap as possible) before a fault had appeared. Customers were pretty happy if we could offer them new tyres at a good price & it counted towards our monthly sales quota - so win/win.
