Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 52
Thread: Tire Sizes
  1. #31
    Aug 2013
    Thank you both for your help.
    I have placed an order for 4 x Michelin PS 4S 245/40ZR19.
    Will see how it goes.
    Sent from my LM-V405 using Tapatalk
  2. #32
    May 2007
    Quote Originally Posted by Vexed View Post
    Did you get a good price? (Over or under $1,000)???
  3. #33
    Aug 2013
    Just a bit over $1000.
    Do they usually sell under $1000?
  4. #34
    May 2007
    No, just curious...
  5. #35
    Pacific Paradise QLD
    Quote Originally Posted by ope126 View Post
    Not implying you are one of the haters (just a general comment)...
    I will have a look at OBDeleven also to see if I can do some fine tuning.
    220kpa (32psi) is the recommended tyre pressure for the Alltrack (as per the Tyre Placard).
    Attachment 48069
    I was going by my Passat Wagon which was 42PSI but I thought it rode a bit hard at that
  6. #36
    Apr 2016
    Clayton
    Just replaced my tyres with the same model P7 for $1270 including wheel alignment, balance etc from Bob Jane after price beat.
  7. #37
    Aug 2013
    I have just fitted my new tyres. So the recommend pressure is 32 PSI for this size?
  8. #38
    See the tyre placard above or on your B pillar
  9. #39
    Jul 2010
    32 psi is a bit too low for a 235/40/19 tyre.
    i normally run between 36-38 psi.
    the tyre placard suggest 240 kpa (34 psi) for 3 adults + luggage.
    270 kpa (39 psi) for fully loaded 5 adults + luggage.
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
  10. #40
    Aug 2013
    Quote Originally Posted by dArK5HaD0w View Post
    That is what the tyre fitter said... I will try 36-38 psi and see how it goes.
    The PS 4S tyres are surprisingly quiet compared to P7 Cinturato. I was expecting a lot of noise after reading some reviews.
