Don't listen to the noise or the haters mate...
Go for the 245/40R19 tyres!
I have the same on my Superb and my Passat Alltrack. I run 220kpa (32psi) for a comfortable ride on both cars...
The Arteon also uses a 245/40R19 tyre.
(On both cars) at an indicated 100km/h read 97km/h on the GPS (BlackVue Dash Cam).
Around 103km/h on the dash is 100km/h on the GPS.
All these cars share the same chassis and components (to a degree), so you will be right!
Due to the Haldex AWD System, you would not want different rolling diameters front to rear...
If you are keen, you can also fine tune via VCDS (not sure if available on OBDeleven as I haven't gone looking yet); Wheel Circumference Change
YouTube
