GVM and Tare?
Although they woud seem awefully high.
Not sure I'd trust those ramps though. They look rather inadequate.
What are your intentions for them?
folks, i'm trying to figure out what the axle weight is, for the purpose of buying car ramps.
based on the stamp (image below) on the door pillar, i'm assuming:-
1. front total = 1060 kg - hence each front axle is 530 kg
2. rear total = 1050 - hence each rear axle is 525 kg
i'm planning to buy car ramps rated at 1000 kg each. i believe this is sufficient.
specifically these ones - Stanfred Car Ramps
thoughts?
p.s. WTF are the weights on the first two rows - 2080 kg and 4080 kg?!?!?!
MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
GVM and Tare?
'07 Transporter 1.9 TDI
'01 Beetle 2.0
This is what's known as a manufacturer’s statutory plate (or "type-approval plate", or "type plate"), which is affixed to every vehicle sold in the European Union, and is required by legislation to contain certain information, such as:
2080 kg - Gross Vehicle Mass
4080 kg - Gross Train Mass or Gross Combination Mass (gross vehicle mass of 2080 kg + gross trailer mass of 2000 kg)
1060 kg - Maximum front axle load
1050 kg - Maximum rear axle load
The tare mass (as per the ADR definition) for your vehicle is 1463 kg. You can find this in the sales brochure.
Thus, given a fuel tank capacity of 66 L, and a density of 0.755 kg/L for petrol, the kerb mass or unladen mass (as per the ADR definition) for your vehicle is 1505 kg.
Assuming a vehicle weight distribution of 62%/38%, the unladen front and rear axle loads are 933 kg and 572 kg respectively.
Or in other words, approximately 467 kg per front wheel and 286 kg per rear wheel.
Therefore, a single ramp rated at 1000 kg (such as that Stanfred ramp you linked) would be more than sufficient.
why are they inadequate?
the other ramps available have a lower rating, and are skinner in width at 210mm - which is much less than the 235mm tyre width of my Superb.
i'll b using to do my own oil changes.
thanks for that much appreciated.
i was fairly positive about the ramps being "strong" enough as they're rated for 4WD use.
but, it has been brought to my attention that the long front overhang of the Superb's bumper might hit the ramp first before the tyres get a grip!!! seems highly plausible.
i gotta try before i buy.
So how do u try before you buy. You measure the ramps lenght and height To the top of the slope and then you get some boards and stick them up under front tyres. Pack them to the height of the ramp at the distance measured.
You will soon find if the splitter will rub.
Just bought a new house and had to do that as the garage has a short rising entrance to the garage. If it was higher than 180mm at 1500mm long the Passat would have scraped and so would the Polo. All is well as it is only 150mm.
