Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Skoda Superb Towbar options (SA)
    Quote Originally Posted by donweather View Post
    Thanks. The Thule ones that clamp on the towball....they don't rotate or sway around the ball when in transit with bikes attached?
    No, when properly clamped on (the euroway has clamp tension adjustment) there's no rotation. The only issue I've had in that respect was on my previous car, where the towball itself was loose and rotated.
    Like the OP I looked at the options for a towbar to fit to my Superb, as others have mentioned getting the coding right is important and I had read that some Superb had the pre-fitted towing wiring loom and some didn't. Mine was pre-fitted so the connections were in place in the boot (on my hatch) if not already installed wiring would have to be run through to the cabin area. I ended up getting the OEM fitted by the dealer, which from memory was around $1900 all up.
    Oct 2009
    Mitchelton, Qld
    I would have thought all cars would come with the pre-wiring already installed and in the spare tyre well. Can anyone confirm or deny for MY20/MY21 superb sportlines please?
