Not sure when you said inserting keys. There is no key hole inside the car but the external door handle on the driver side for emergency if battery(or central locking got issue) as you mentioned your is KESSY optioned/equipped
If your KeyFob is out of (lithium watch size) battery , inside the steering column there is a sensor next to the stop/start button where you place the key nearby and push the stop/start button to start the car.
I doubted they have a 3rd party electronic key.. plus they need to be re-programmed and synch all the keys with the car at the same time
