Results 11 to 20 of 24
Thread: Loan of Superb for 30 Minutes
    I think there is a bit of confusion, the Elegance gets bi-Xenons, I'd be guessing that the Ambition has Xenons for one beam only. Either way I didn't know that as bi-xenons are an option for them so I assumed they were Halogen by default.
    Jun 2006
    Sunshine Coast
    My ambition has bi-xenons
    2018 Skoda Superb TDI
    2010 Skoda Superb TDI
    2009 Golf VI 118 TSI
    2006 Multivan TDI SOLD
    Dec 2010
    Helensburgh
    Quote Originally Posted by woofy View Post
    Sorry but you are guessing wrong. The ambition has the full shebang of bi-xenons with the self leveling and the speed focus system but also has a H3 inner globe that works as a headlight flash and also on high beam. In this country in respect of the headlights there is no difference between Ambition and Elegance. I was going to trade the Ambition and buy an Elegance wagon but the difference in equipment levels is not great enough to make it worthwhile as mine came with leather as part of the deal and I just don't get the whole Columbus adoration scenario. Beyond those two things there is not much difference that I can see on the base cars before extras.
    Jun 2009
    Quote Originally Posted by Ozsko View Post
    No again. Unless optioned accordingly, the Ambition comes with projector beam headlights, whereas the Elegance comes with bi-xenons. Unless the headlights are actually on, there is no visual difference between the two.
    Mine: Silver 2006 Volkswagen Golf Sportline 2.0FSI 6M (with a sunroof)
    Parents': Candy White 2008 Skoda Octavia RS 2.0TFSI 6M Liftback
    Dec 2010
    Helensburgh
    Explain how mine has bi-xenons then. A mistake on Skodas part? Also the post above whose car also has them.
    I've not really heard of bi xenons with H3 headlight globes. Bi xenons means both low beam and high beam are xenons. Some are low beam only, and in that case are not bi xenon. That would be what I guess the ambition might come with. Seeing as yours has leather all bets are off though as it's not stock spec and has had at least one factory option fitted.
    Unless the website and brochure is wrong, the specify bi xenons as standard on the elegance and an option on the ambition, they change specs a lot so it might not have always been like that. I've been watching them since launch though and don't recall xenons being standard, but it might have been due to them listing the bi xenons as an option.
    Dec 2010
    Helensburgh
    Sorry I mislead you, the leather was a dealer fit in Oz, not a factory fit. I would not be willing to bet anything on the spec of the cars that were brought in as initial stock. Mine has hill hold as well as the MF steering wheel and none of this was specified as an option. Is the MFSW a standard fit by the brochure? As for the H3's all cars for instance in the UK have them to supplement the xenons for the reasons I stated, what car have you seen with bi xenons and no H3"s?
    Jul 2010
    all bi-xenon factory fitted cars generally have a halogen reflector unit for high beam flashing purposes.
    it is impractical & inefficient to b using the d1s (xenon) globe to "flash", for watever reason, due to the igniting voltage required and the startup times for it.
    hence a halogen setup is required. in the superb's case - using a h3 globe.
    doesn't matter if u have xenons or bi-xenons, ur superb will still have a "high-beam" halogen reflector (closest to the grill). even those not equipped with xenons.
    the only difference is with bi-xenons (afs II), when u need high beams, not for flashing, the projector cutoff is changed for the beam pattern to show further away.
    with normal xenons, when u need to use high beams, again not for flashing, the halogen r used. that's the behaviour with the vRS, optioned with xenons.
    don't assume that just because the low-beam unit is a projector housing that u have xenons.
    for some reason a lot of ppl think that a projector headlamp = xenons!! it doesn't!
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
    Dec 2010
    Helensburgh
    I got my car back from the dealer today after the third visit to rectify the headlight problem and they are still stuffed. They assured me they had driven it at night which they might have, around the block. I think I am going to have to have a long and meaningful talk with the service manager and mechanic and assure them they have not fixed it. BTW they have had it since last Monday and I said I did not want it back until today to give them plenty of time to fix the lights and do a service. It goes back on Monday and I am not having it back until it is fixed as I have another car to drive so am not dependent on it. The next time I get it back someone is going to come for a ride in the dark before I take delivery.
    Dec 2010
    Helensburgh
    Quote Originally Posted by thejack72 View Post
    We're in St George area. PM me if you don't get anybody closer.
    Craig, thanks for coming all the way down and letting me see what your lights were like in comparison, much appreciated. An interesting hour long chat about Superbs and what can be done to them.
