Thanks guys,
Got into the setup.
Shakey, get in and start the car. On the right hand side of the steering wheel press and hold the lower button. The display will change. You can then select the menu items using the rotary button. When you have highlighted the one you want press the rotary button. The rotary button allows you to scroll and it is also a button if you press it.
