Results 1 to 10 of 10
Thread: Kessy and remote
    Dec 2012
    Sydney NSW
    Kessy and remote
    I'm just getting use to everything. When opening with the kessy system do only the front doors open? I'd like to be able to walk up to the car grab the handle and the car unlocks and then everyone gets in. When using the remote is this achieved using two clicks on the open? Is any of this configurable in the system?
    Thanks
    Andrew
    Oct 2009
    Yep, you can. There is a setting in the MDI that you can change so it unlocks all doors when you reach for the driver's door with the KESSY key in your pocket.
    Apr 2010
    You mean MFI (aka MFD)
    I always make that mistake too
    Oct 2009
    Kessy and remote
    Where did I get MDI from? Must be late? Nope, not late, must be too many reds.
    Nov 2012
    Quote Originally Posted by Legion View Post
    Thanks
    Andrew
    Andrew...when you fing out how to do this can you let me know. I've had my car three weeks now and it *****s me too when all doors don't unlock.
    Jul 2010
    if your MFD.....
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
    Dec 2012
    Sydney NSW
    Thanks guys,
    Got into the setup.
    Shakey, get in and start the car. On the right hand side of the steering wheel press and hold the lower button. The display will change. You can then select the menu items using the rotary button. When you have highlighted the one you want press the rotary button. The rotary button allows you to scroll and it is also a button if you press it.
    Nov 2012
    Thanks guys,
    Got into the setup.
    Thanks guys....will work on this tonight when home from work. (I no longer leave my car at the railway station car park!!!)
    Dec 2012
    Sydney NSW
    The other one to set is the lane change flash. With it turned on you move the indicator and release and it will flash three times and then stop.
    Wollongong , NSW
    Quote Originally Posted by Shakey View Post
    As the guys on the Briskoda site say; RTFM. It's all there. I worked my way through it bit by bit over a month. When I wanted to know about lights I read the whole section on lights, then windscreen wipers etc. I am still reading bits as I forget easily
