Yep, you can. There is a setting in the MDI that you can change so it unlocks all doors when you reach for the driver's door with the KESSY key in your pocket.
I'm just getting use to everything. When opening with the kessy system do only the front doors open? I'd like to be able to walk up to the car grab the handle and the car unlocks and then everyone gets in. When using the remote is this achieved using two clicks on the open? Is any of this configurable in the system?
Thanks
Andrew
You mean MFI (aka MFD)
I always make that mistake too
if your MFD.....
MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
Thanks guys,
Got into the setup.
Shakey, get in and start the car. On the right hand side of the steering wheel press and hold the lower button. The display will change. You can then select the menu items using the rotary button. When you have highlighted the one you want press the rotary button. The rotary button allows you to scroll and it is also a button if you press it.
The other one to set is the lane change flash. With it turned on you move the indicator and release and it will flash three times and then stop.
