Results 1 to 9 of 9
Thread: Heads Up on DPF Sensor
    Dec 2010
    Helensburgh
    About nine months ago I had a DPF sensor failure and had to replace it. Ever since then the car has had an engine light on and if the code was cleared the engine light came back of a day or so later. I was working night shift through a lot of this period and took the approach that the car still worked so stuff it and I will get it fixed when I have time.
    The time came last week when the car went in for service. I told them to sort it out and I didn't want to see it until it was fixed as I had another car to drive. They had a crack at fixing it by replacing the sensor that was new less than a year ago and test drove it overnight declaring it fixed. i was sceptical to say the least and sure enough it came on again and was back to the dealer the same day.
    After a lot of mucking around, multiple sensors and then getting VW tech involved it turns out that there is a parts supercession on the sensor as it is a known problem but no one had bothered to circulate a tech bulletin. It has taken the best part of a fortnight to sort this out and full marks to Southern Classic Cars in Wollongong who swallowed the cost of the whole thing. I can't ask better than that.
    Mar 2013
    Brisbane QLD
    its been a known issue for about 2 years now....part number changed multipul times back then...there are two different part numbers depending on engine code..may be they fitted the wrong one.... VDUB....
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Dec 2008
    Sydney/Canberra
    May also need the ECU adapted to the new sensor.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Mar 2013
    Brisbane QLD
    yeh..when the new sensor G450 was fitted the ecu should have been adapted to the sensor and then a fored regen of the DPF to clean out the system....
    Adelaide hills, SA
    Also, the fault on the dash requires that the driver seeks the workshop in much shorter time than several months (9months), otherwise there is a great risk that you will clog the DPF beyond regeneration and it will need replacing.
    The logged faults will reveal that the driver was driving for the extended period of time and most likely asked to pay for the clogged DPF.
    Dec 2008
    Sydney/Canberra
    Yes, ^that as well.
    Never just keep driving with the engine fault light on with a modern diesel. Get it checked out and fixed as soon as possible.
    '01 Beetle 2.0
    Mar 2013
    Brisbane QLD
    DPF under warranty is very rare..only ever seen one go through...and they are so expensive!...
    Jun 2007
    Quote Originally Posted by Umai Naa!! View Post
    Yes, ^that as well.
    I recently had an engine warning light come on in my Octavia. Turned out to be a pressure differential sensor. The dealer told me the rule is to keep driving as long the engine is performing normally.
    Adelaide hills, SA
    Quote Originally Posted by PassatB6 View Post
    That's a bit silly to say. They were probably to busy to fit you in.
    It doesn't take that long to replace it.
