Originally Posted by
2009fsi
No Albervin, I have had no need to reset the computer. I've owned it just on 9 months. The car still has less than 20k on the clock, 3 services by Skoda who haven't needed to reset it either. (Only thing other than fluid changes done was to change the Bolero display because of dead pixels.)
The life of car consumption reading has never been reset during service by Skoda. I find it very interesting, to see the effect on the LT consumption of long distance cruising. I reckon when I sell the car privately eventually, it will be immediately after a long county run; when the figure looks its most impressive. I'd hate to see the figure on a city only driven car.
Re: your comment on using manual mode a lot. I also prefer it a lot of the time. Sports Mode lingers in lower gears too long into the peak before changing. No wonder it consumes so much juice. Drive mode works fine in urban areas, but I find it tends to linger around 4th when the car is quite comfortable in 5th & so on with 6th. I never put the DSG in Drive & just leave it like an auto. A DSG is in essence a dual clutch manual with an electronic clutch. I always put the car in neutral when it stops. I've been a life long manual driver anyway. I made a comment some months ago about the same thing effecting consumption in urban use. Since then I've tended to do it manually most of the time, short shifting to higher gears earlier than the Drive program allows. I think it does make a difference.
Unless the Superb is different to the Octavia then AVG Consumption (2) resets every 99hrs59m That's somewhere between 3500-5000km depending on how much traffic you get caught in. So it's probably reset itself about 3-5 times in 18,000km. If you drive around with the MFD on AVG(1) then you probably wouldn't notice the reset.
DSG in neutral at the lights isn't a good idea if other reports on this forum are anything to go by.
