Results 1 to 6 of 6
Thread: Electro tailgate no-go
    Jan 2017
    FNC, NSW
    Greetings all.
    It isn't showing any faults on the VCDS but the leccy gate, she no-go.
    First motor locks and unlocks fine but the open/close deal is out to lunch. No go on fob, console or door.
    Could something have come away on the relevant motor, some kind of activation arm or something?
    Getting 5 'hazard' beeps on trying to open or close.
    Any ideas greatly appreciated.
    Oct 2016
    Townsville, QLD
    This is on a MK3? Should be covered by warranty at least.
    If it is a MK3, have you had the recall done to remove the signal booster? When mine was done, they accidentally disconnected one of the little motors that releases the luggage cover automatically, could have done something similar in yours that has effected a sensor?
    Jan 2017
    FNC, NSW
    It's an MY11 Mkii.
    Has been working fine for years.
    May have to pop the trim off to see what i can see.
    Quote Originally Posted by IMSancho View Post
    Jul 2010
    did the mk2 superb come with electric tailgate?
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
    Jan 2017
    FNC, NSW
    Quote Originally Posted by dArK5HaD0w View Post
    I'm the second owner.
    I believe the previous owner had it all sorted as it was in place but not activated. Was working from fob, console and door.
    Jan 2017
    FNC, NSW
    Further to this. Will drop into VCDS thread also.
    Friday,20,October,2017,09:50:07:40733
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 17.8.0.1 (x64) HEX-NET CB: 0.4401.4
    Data version: 20170721 DS276.2
    Ross-Tech: Home
    Mileage: Repair Order: 201017
    Address 6D: Trunk Elect.
    Control Module Part Number: 7N0 959 107 A
    Component and/or Version: HDSG-Modul H11 0802
    Software Coding: 082301C002
    Work Shop Code: WSC 33361
    VCID: B522611A14DEEBEEE9-80E0
    Advanced Identification/FAZIT
    Serial number: 250000031
    Identification: TF7-MNL
    Revision: 41011001
    Date: 07.09.10
    Manufacturer number: 0001
    Test stand number: 0031
    Flash Status
    Programming Attempts(application): 0/0/0
    Programming Attempts(data): 0
    Successful Attempts(data): 0
    Programming Status: 00000000
    Flash Date: 00.00.00
    Flash Tool Code: 00000 000 00000
    Flash Tool Code(data): 00000 000 00000
    Software
    UDS: 01.02.14
    Diag: 01.03.00
    CAN: 01.26.01
    ISO15765: 01.02.15
    UDS Std Diag: 01.01.00
    Theft prot.: 00.00.00
    OSEK-OS: 03.24.00
    OSEK-Com: 04.07.02
    Unknown: 01.00.08
    Misc.
    Hardware number: 7N0 959 107 A
    Workshop System Name: ----
    Equipment/PR Code: 0000000000000000
    Dataset Number: 7N0959107A
    Dataset Version: D009
    ASAM Dataset: EV_HDSGSk462
    ASAM Dataset Revision: 301133
    Car Info
    Chassis Number: -----------------
    VCDS Info:
    Labels: 7N0-959-107.clb
    ROD: EV_HDSGSk462_SK46.rod
    Friday,20,October,2017,09:51:25:40733
    Ross-Tech: Home
    Address 6D: Trunk Elect. Labels: 7N0-959-107.clb
    Control Module Part Number: 7N0 959 107 A HW: 7N0 959 107 A
    Work Shop Code: WSC 33361 790 00999
    ASAM Dataset: EV_HDSGSk462 301133 (SK46)
    1 Fault Found:
    0004 - No Basic Setting
    B2010 00 [137] - -
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 129
    Mileage: 126440 km
    Date: 2080.14.29
    Time: 10:46:56
    12.64 V
