Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: DSG in the wet
    Dec 2012
    Sutherland Shire, Sydney
    Quote Originally Posted by notflyingscot View Post
    I think its just a case of either getting used to the "hill holder" or reverting to conventional handbrake hill starts in the wet.
    It's the brake assist
    I don't actually know what the car will do if you manually use the hand brake but there should not be any need to do so.
    Hold the foot brake, ensure the car is stationary, look at the MFD and check the car has selected 1st gear.
    Confidently lift foot off the brake and then ease into the accelerator
    If the car tries to change into 2nd and that is causing problems put the car into manual and select first, hold it in first until your underway
    If it does not work then maybe there is a DSG/Clutch issue - get assitance from your dealer service centre
    I actually bought the Superb after being really happy with a new rental Skoda I drove in the UK (which sadly was written off as we sat stationary at a junction but that's another story!)
    Yikes!!!
    Jan 2011
    Brisbane - QLD
    My right foot has been retuned with stage 2 software for more modulating control ability and i have not had much dramas on wet
    Sent from my GT-I9300T using Tapatalk
    MINI Cooper S Clubman - FWD
    Jul 2010
    Quote Originally Posted by Martin View Post
    its not the brake assist - it's the "hill hold control".
    i don't know about the superbs, but on the octavia rs, hill hold wasn't available till MY09 or MY10, after which it was made a std fit.
    from the rs my11 brochure:-
    "ESP - Electronic Stabilisation Program (incl. ABS, EBD, ASR, XDL and hill hold control)"
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
