Results 1 to 3 of 3
Thread: Brake pads / rotors sizes ?
    Aug 2019
    Hi all,
    I need to get new brake pads and rotors (front for now) but I seem to be unable to get the sizing anywhere. There was supposed to be a coded information on the sticker you can find in the boot where the space saver tyre is (or in the manual booklet), but I have no code there related to the brake rotors info.
    Just trying to source some good value for money ones that will fit no problem.
    cheers
    May 2007
    More info needed bud...
    140TDI / 162TSI or 206TSI??? (Assuming you are referring to MK3 Superb's);
    ATE Ceramic Brake Pads
    (front) Article No. 13.0470-2785.2 / 25684, 25683
    (rear) Article No. 13.0470-7294.2 / 25011, 25009
    ATE Coated (High Carbon) Vented Rotors (312mm) Original ATE brake discs
    (front) Article No. 24.0125-0158.1 / 425158
    ATE Coated Solid Rotors (300mm)
    (rear) Article No. 24.0112-0210.1 / 412210
    For your info, here are the original part numbers also.
    Original Volkswagen Part Numbers;
    - (front) 312mm Rotor - 5Q0698151F
    - (rear) 300mm Rotor - 3Q0615601A
    - (front) Brake Pad - 5Q0698151F
    - (rear) Brake Pad - 3Q0698451C
    These are to suit 140TDI and 162TSI only...
    May 2007
    If you have a 206TSI;
    ATE Brakes: (Front 340mm / Rear 310mm both Vented)
    Front Rotors (340mm): Article №: 24.0130-0225.1 / 430225
    Front Pads: Article №: 13.0470-2617.2 / LD2617
    Rear Rotors (310mm vented): Article №: 24.0122-0219.1 / 422219
    Rear Pads: Article №: 13.0470-7294.2 / LD7294
    Original ŠKODA Part Numbers;
    - (front) 340mm Rotor - 5Q0615301G
    - (rear) 312mm Rotor - 5Q0615601E
    - (front) Brake Pad - 5Q0698151K
    - (rear) Brake Pad - 3Q0698451D
