Results 11 to 20 of 21
Thread: Alarm goes off unexpectedly
    Dec 2014
    Gungahlin ACT
    In fact it had an NRMA battery in it that i replaced.. the Factory battery was long gone
    Dec 2014
    Gungahlin ACT
    do you know the oil capacity for my car? I believe its 4.5 litres ? Can you confirm that?
    2009 Skoda Superb Sedan - 3T ELEGANCE DSG FWD 7 Speed - 148kw 290nM (thank you Northside Eurpopean Mitchell ACT 02+ 6241 1111) 1.8 TSI...114,987km
    Quote Originally Posted by AALocksmiths View Post
    No worries. I don't suppose when they swapped the battery they tested to see how many amps your car is draining when OFF? I know some VAG cars have issues with battery draining caused from an issue with the CAN-BUS as well as accessories fitted to the car. It might be something that has contributed to the death of your battery.
    Interesting info - and likely the reason why my car used to run the battery flat (or near flat) when i didn't drive it for 7-10 days......my P3 gauge which plugs into the OBD-II port must have been slowly draining power.
    Quote Originally Posted by ashmannnn View Post
    no... they didnt do that... i had the alarm go off on New Years eve whilst it was parked in a friends driveway.....I hope this isnt the start of something annoying....
    Press the lock button twice (which will disarm the interior motion sensors) and see if this stops your alarm going off. My Mk6 Golf used to do the same thing (and always at 2am of course) even though the car was all closed up and in my carport.
    I think its about 4.3L or thereabouts in the 1.8 and 2.0 TSI engines - your owners manual will confirm. I always have around 0.5L left from a 5L container after doing an oil change.
    Dec 2014
    Gungahlin ACT
    just wanted to make sure my mechanic put enough oil in at the change.... will try the lock button twice trick... see if that helps... thanks
    Pacific Paradise QLD
    Wouldnt you find out if you pulled the dipstick out.
    Dec 2014
    Gungahlin ACT
    Yep... but not always so easy as for some reason Skoda (VW) make the dipstick black so as to make it hard to read in some light. Why they dont make it stainless steel silver (like it used to be) is beyond me.
    Pull it out wipe it off put it back pull it out and if you cant see run your finger down from above till you feel it Dont need much light to get a glint off the liquid
    Dec 2014
    Gungahlin ACT
    Yes ok, thank you hillbilly.
