Results 1 to 4 of 4
Thread: Additional Jack Points
    Jul 2010
    in my effort to figure how to use axle/jack stands - i discovered additional points, not covered in the manual, or anywhere else on the web.
    since the jack and stand can't fit side by side, i had to find alternate positions.
    happy to b corrected if these are NOT jack points.
    car is an MY17 162TSi Superb Sedan.
    rear one has a rectangular cover...
    Additional Jack Points-jack_08-jpg
    rear one with cover removed.....
    Additional Jack Points-jack_03-jpg
    front one has a circular plastic cap......
    Additional Jack Points-jack_05-jpg
    front one with plastic cap removed.....
    Additional Jack Points-jack_06-jpg
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
    Dec 2008
    Sydney/Canberra
    I wouldn't use those spots. Just stick to the ones on the sills.
    For me, I use these:
    Additional Jack Points-220166-zoom-jpg
    Caravan levelling ramps to raise the front of the car up.
    Additional Jack Points-322396-zoom-jpg
    Jack stands under the sills at the advised jacking points.
    Additional Jack Points-424147-zoom-jpg
    Low-profile trolley jack, to lift the front of the car at the crossmember.
    To raise the rear is a little trickier, and heavily dependant on the car. I tend to just lift it at the rearmost crossmember bolt on either side. Gently, as it can sometimes be a little dicey.
    I do this several times a day, most days of the week on VAG vehicles. If you use common sense, you won't have any issues.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jul 2010
    My preferred choice would b car ramps.
    But the ones from Supercheap/repco etc etc do not clear the front bumper.
    The caravan ramps far to low height wise.
    I'm not planning to go buy a pair of caravan ramps, trolley jack and Jack stands.
    I'm buying just a pair of Jack stands.
    All those points r on the sub-frame or chassis.
    There are two identical ones at the rear, and two identical ones at the front.
    I'm no mechanic, so I can't confirm.
    But it sure as hell looks like very plausible jack points.
    I couldnt take a pic of the actual point - it is solid metal.
    Looks more safer than the sill jack points if u ask me.
    Jul 2010
    in these "exposed" pics (not my car) u can see the rear jack points more clearly, which i pointed out in my earlier pics.
    it just so happens on my car, there is a plastic undertray infront of the rear wheels - hence u can't see the chassis frame on mine.
    but in the images below - the plastic cover is removed, clearly showing the chassis.
    red = additional points
    green = "advertised" or known points
    Additional Jack Points-jack_00-jpg
    Additional Jack Points-jack_01-jpg
    Additional Jack Points-jack_21-jpg
