Results 31 to 35 of 35
Thread: In addition to Clutch Plates
  1. #31
    Aug 2013
    Kings Langley, NSW
    That's not so good to hear. Touch wood but have not had to put a teaspoon of oil into ours between services to date. No comfort to you I'm afraid!
  2. #32
    Dec 2014
    Gungahlin ACT
    no.. but glad yours is running ok..... I am sure its normal despite what Lennock say...
    2009 Skoda Superb Sedan - 3T ELEGANCE DSG FWD 7 Speed - 148kw 290nM (thank you Northside Eurpopean Mitchell ACT 02+ 6241 1111) 1.8 TSI...114,987km
  3. #33
    Jan 2010
    Bathurst, NSW
    Yeah, some seem to use more oil. Not sure if its how the engine is run in or bad luck. Has yours been modified? Your sig seems to indicate more power?
    Our 118tsi is still full after 11000kms. Run in without any attention paid to the run in schedule (first 2 thousand Ks a drive to coffs harbour and back - which is supposedly not ideal).
  4. #34
    Erskineville, NSW
    Quote Originally Posted by ashmannnn View Post
    but sadly not full of oil after 5000km... needed a litre or so... rang the dealer... was told that i should expect a little oil usage before the first service... so does that also apply to a new car? Does a new car use a litre of oil before the first service? I dont think so... any one have any thoughts? I have emailed the dealer in writing with my concerns..... guess we will see at the first service...
    To paraphrase the owners manual:
    Your engine may use more oil than normal while running-in. It is recommended that initially you check the oil at every fuel fill. After running-in your engine may use up to 500ml per 1000km and this is considered normal.
  5. #35
    Dec 2014
    Gungahlin ACT
    Sure thanks brad.... will bear that in mind... slight ECE remap... but has standard tune in at the moment.
