I don’t suppose you’ve done a VCDS scan by any chance?
Did you disconnect the wiring when you pulled it out.
Ignition on then off and tap stalk down should be the procedure but you obviously know that as you’ve done it before.
I was thinking maybe bonnet switch faultbut that would stop the wipers altogether.
