Results 11 to 20 of 21
Thread: Wipers & Washer Pump problem on GT GOLF mk5 (not working)
    Sep 2011
    Bathurst
    Hey guys, sorry to necro this a bit, but I'm having this exact same problem. I'm wondering if a resolution was ever found?
    To state out exactly what I'm seeing:
    Golf GTI Mkv 2006
    Front washer jets don't work
    Rear washer jets don't work
    Rear windscreen wiper doesn't work
    12v Cigarette lighter connection no voltage
    Heated seats don't work
    All of these failed at the same time.
    Jul 2007
    Brissy
    Did you check over everything covered in this thread ?
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Sep 2011
    Bathurst
    Well I'm trying to discover if a solution was ever found. Sounds like lots of tests were done to isolate a part, but nothing was done that actually "fixed" it.
    I'm planning on poking about with a multi-meter on the weekend.
    Apr 2008
    My Golf 5 is doing this also. I thought I'd just take it to my auto electrician but don't have time.
    Jul 2012
    Sinagra, Western Australia
    All run off the same relay if i remember correctly. Can probably bring it up on elsa to check tomorrow if i remember
    Volks Handy
    Servicing - Repairs - Diagnostics - Mobile fault scanning/clearing - A/c work
    10 years experience working for Audi/VW/Skoda
    Now in Perth NOR, Western Australia.
    Jul 2012
    J59 relay is the one, bridge the secondary circuit with some suitable wire. If all works then test the relay with a multimeter and a 9V battery. Relay faulty, replace, otherwise time for an auto elec.
    Wipers & Washer Pump problem on GT GOLF mk5 (not working)-1kunderdashrelays-jpg
    Volks Handy
    Apr 2008
    Ah sweet, thanks for the effort!
    Will report back
    Aug 2018
    South Africa
    Sup guys.
    Hope you're not sleeping yet...
    I have the exact same issue as OP, rear wiper and washer, front washer, 12v socket. Have not checked heated seats.
    All fuses have been check and look OK.
    I have been googling last few days and self-diagnosed a faulty module. A replacement unit is F**K expensive.
    Am I correct is saying that the solution is to replace the J59 relay? (not to be confused with J519 module)
    Mitch
    Aug 2018
    South Africa
    So....
    Thursday after work I decided to remove all the panels below the steering wheel to get to the relays and see what is going on and how difficult of a job it would be to replace the j59 relay (no 460). very difficult. couldn't get anything near the tabs to get it out.
    I noticed another 460 relay on the other side (see item 1 on the picture on post #16)
    I had an idea to swap them to see if it was indeed the relay. It was getting dark and I gave it a miss for now.
    Friday morning whilst driving to work I decided to try my heat seating, to confirm if they were also not working. Driver side was working, then decided to try passenger side. after 30 sec of switching it on, the cigarette lighter popped up! So it had suddenly got power. I tested washers front and rear and all were working! Awesome!
    Saturday morning, everything not working again....
    So back to plan of swapping the relays. Today was that day.
    Long story short, I broke 2 jewelers screw drivers when bending them into a "L" shape so I could get to the tab under the relay. Eventually I used a larger long thin screw driver to break both top and bottom tab off. Not a proud moment, nor very delicate.
    Swapped the relays and boom! washers etc. work. So I know for sure its a faulty relay. Or a coincidence of some sort.
    I hope this helps others one day who run into the problem. I will take pics of the area under the dash to give an idea of what needs to be done.
    It might have been easier if I tried removing the entire J519 module, but I did not know how.
    Dec 2008
    Sydney/Canberra
    Yeah never rule out a faulty relay.
    Having wiring diagrams certainly makes them easier to diagnose though.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
