Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Wiper resevoir... no warning?
    Hi all,
    Just had to fill my wiper resovoir with water & two capfills of VW magic fluid but had no warning at all that it was about to run out.
    The owners manual states that I should have had a warning before this occurred is this normal or is this a downgrade as I have on '07 spec car?
    Has anybody ever had a warning B4?
    Do not want to scratch my windsceen and always counted on this feature!
    cheers ferg
    2006 Jetta TDI Manual
    Dec 2006
    EPPING, NSW
    Yeah my mate was reading my manual and he asked about it.. NO SUCH luck when i ran out of water. Also there when i ran a flat tyre there apparently is a thing which warns you of low tyre pressure.. DIDNT HAPPEN. obviously not on mine... (06 sportline golf)
    brackie Guest
    Other things not set up
    gtimk5 and I were looking at my TDI yesterday and finding similar things to those that you guys are mentioning. We came to the conclusion that the computer wasn't programmed to my specs when I picked the car up from the stealer. The salesman at no time mentioned to me the programming options available and it wasn't until I read forum posts and talked to Andrew that I realised that they should have been set up on delivery. Apparently the stealers charge you for setting them if you go back. I have to have the radio/flat battery recall sorted on my TDI and while I'm there there's gonna be a bunfight!
    But don't you love the smell of the washer fluid?
    Feb 2007
    SE Qld
    Question What are the Programming Options?
    Quote Originally Posted by brackie View Post
    How many programming options are there? It would be great to know what could/should be asked for when purchasing the car, ie: if this forum could generate a list?
    Are the options described throughout the manual?
    Just found this (as a start)...
    Quote Originally Posted by EUS GTIMK5 View Post
    You should have got them all done prior to delivery. I asked for the following to be set up when I got my car. I think some may be "standard" features but it's prbably safest to ask. -
    1. One click - all doors open.
    2. If car unlocked - Hold down close/open button and all windows close and car locks.
    3. If car locked - Hold down close/open button and all windows open and car unlocks
    3. Auto lock after 20 kmh. Again got kids.
    4. Auto open when doors locked and key removed from ignition
    5. No horn to sound when lock car.
    6. No horn to sound when unlock car.
    7. Courtesy head lights set time to 20 seconds
    There may be others but I think tese are the main ones?
    Mar 2007
    Hitlon WA
    I know I do ...... love the smell of washer fluid
    Edit
    Are above options available in Comfortline ?
    Nov 2006
    Canberra, Australia
    I thought the tyre pressure monitoring system was only on GTIs for Australia??? Anyway, if you car has the functionality there will be a TPMS button on your centre console just behind your ashtray & gear stick.
    MY10 S3 3dr
    Mar 2007
    Hitlon WA
    Quote Originally Posted by minigolf View Post
    Ok... maybe not a tyre pressure but what about whiper warning
    Edit
    My 2.0TDI has no such options
    Mar 2007
    Nope, count the Jetta in for that function...it works too. If you check your tyres at the garage using the "set to 36psi auto pump" and forget to reset the thing - it will squeel when the tyres heat up.
    I was heading off to Bris, ex Syd, checked the 5 tyres, didn't think to reset the thing. 0330 - set off the next morning, got all warmed up 10km down the road...BING...you have a flat....GRRRR great way to start the trip...alas..it was only the sensor.
    Apr 2006
    Hobart,Tas
    I have reset the tyre pressures on my GTI a few times by as little as 3lbs. and had the warning go off down the road. I have also destoyed 2 tyres on out Tassie roads and the warning has alerted me welkl before the loss of pressure was noticible looking at the tyre.
    I spose the normal check over of your vehicle includes topping up your washer fluid rather than waiting for the warning to appear?
    My old Mk4 one alerted me once for low level when I was slack in not topping it up.
    Cheers, Andrew
    Wiper resevoir indicator not installed on 07 Jetta's
    Hi all,
    had the Jetta in to the dealers to get a faulty window motor replaced, whilst there I asked them to check why there was no resevoir warning. I was told "the resevoir warning was not installed on this vehicle".
    So it seems that an '07 spec car no longer has this facility, hardware rather than software Brackie... shame, cos as gtimkv said check it regularly sounds good...... only trouble is it is a little hard to see as the bulk of the tank is out of view!
    Anybody got this feature that works on their car... maybe it is only on USA versions?
    On a more positive note my tyre pressure warning sytems works fine ignore it at your peril!
    cheers Ferg
Similar Threads
  1. Bora - Oil Pressure Warning
    By pursuit_ute in forum Mk4 Golf & Bora and New Beetle
    Last Post: 20-10-2006, 10:41 PM
  2. Mk III Golf - Rear Wiper Issue.
    By WEDEL.1 in forum Mk3 Golf & Vento
    Last Post: 17-07-2006, 06:27 PM
