Results 1 to 4 of 4
Thread: Windscreen Washers Failed/Fuse Diagram
    Dec 2010
    Question Windscreen Washers Failed/Fuse Diagram
    Hello VW-ists,
    I had to change a fuse for my 12V cigarette lighter socket a few weeks ago and since then my windscreen washers have stopped working - pretty annoying going into winter and having the car parked outside overnight. I'm hoping it's just a fuse, and for some reason I cannot find the related fuse on any fuse diagrams I have seen online and in the owner's manual.
    The wipers, thankfully, still work, however the "buzzing" noise when the water comes out has stopped.
    Thought/solutions welcome.
    Julius.
    2010 B6 Passat 125TDI Black, leather, RNS510, boringly comfortable
    Aug 2011
    It may be the washer pump has died (no sound), mine died last week and is about to be replaced.
    Mar 2013
    Brisbane QLD
    more than likely the pump or rodant damage to wiring we are seeing alot of now.. possible also stalk or control unit but will try and look up the fuse number for you today...VDUB..
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Mar 2013
    Brisbane QLD
    SC42 15AMP ... SC are the fuses on the right hand side of the dash behind the oval panel.. power should be from there and its earth controlled by central electrics.. if you want me to totally confirm 100% its that fuse send me your VIN number....VDUB...
